2024 Tacoma TRD Off-Road Premium Hybrid rear sliding power window relay question.
mkinzer126
Georgia
2024 Tacoma TRD Off-Road Premium iForceMax Hybrid
Hello everyone. I just bought a new 2024 Tacoma TRD Off-Road Premium iForceMax Hybrid 4x4. I love it so far. When I brought it home Monday night, I was going over the truck and noticed that my power rear sliding window did not work. I looked for a blown fuse and found none. I followed some of the posts on this forum and saw there were fuse / relay box locations in the cab and two under the hood. The passenger side under hood fuse/relay box seems to be where the relays that control the power rear window are.
Problem is... my truck had no relays plugged into the P/W BACK NO. 1 or P/W BACK NO. 2 relay slots. I did however have two brown DENSO relays part # 90084-98032 plugged into TAIL GATE NO. 1 and TAIL GATE NO.2 relay slots. For testing, I removed the two relays from the tail gate #1 and #2 slots and put them in the P/W # 1 and #2 slots and the sliding power rear window now works as it should. I saw another post of a guy with a 2024 Limited Hybrid Tacoma and he doesn't have the relays for the Tail gate #1 or 2 slots and doesn't even look like he has the wiring in the fuse box for the relays.
So my questions are:
1. Did the factory just misplace the two relays in the wrong slots?
2. What do those two TAIL GATE NO. 1 and TAIL GATE NO.2 relay slots actually do? What features won't work now that those two relay slots are empty? I tested everything I could think of and everything works as it should. I have the power tailgate and it still works perfect. SO do the USB and power ports in the rear. (Have not tried the 120v 2400w plug in the bed yet.)
Pictures attached. Picture below with empty relay slots circled is AFTER I moved the relays. Circled slots are the now empty two TAIL GATE NO 1 and 2 relay slots. I moved the two brown relays from the circled slots to the two slots above labeled as P/W BACK NO 1 and 2.
2024 Tacoma 2024 Tacoma TRD Off-Road Premium Hybrid rear sliding power window relay question. IMG_7658
2024 Tacoma 2024 Tacoma TRD Off-Road Premium Hybrid rear sliding power window relay question. IMG_7657
2024 Tacoma 2024 Tacoma TRD Off-Road Premium Hybrid rear sliding power window relay question. IMG_5580
2024 Tacoma 2024 Tacoma TRD Off-Road Premium Hybrid rear sliding power window relay question. IMG_7656
Sner
Let me try and understand. You spent over $55K on a new truck that has a new car warranty. You take the said vehicle home, and on the way home you realize the power sliding window doesn’t work. Rather than turning around and going back to the dealership you decide to go home and start tinkering with your new purchase. Needless to say you can’t figure out the problem, so you then decide to take to a Tacoma forum and spend time uploading pictures and typing up a post.
It seems almost too good to be true - likely click bait, and yes I’ve just become a victim. But here’s my advice.
You can’t be helped!!
mkinzer126
mkinzer126
Georgia
Sorry. I thought this was a forum where people actually want to learn and understand how things work. I did get the power sliding rear window to work, AFTER moving the relays from the slots circled in the first picture to the two slots they are in now. IT NOW WORKS. I'm trying to understand what those two TAIL GATE #1 and #2 relay slots that are now empty actually do. I've tested everything on the truck and all my features work.
mkinzer126
mkinzer126
Georgia
I get it...no wants to deal with a "dealer service dept."..But she is under warranty and I would head straight there...jmho
Thank you. I have it working now. Just trying to understand what those two empty TAIL GATE #1 and #2 relay slots do.
BoboForShort
Tyler
Do you have a power tailgate? I would imagine that is what they do? Take it to the dealer and they'll fix it up for free and replace whatever relay you may be missing.
mkinzer126
mkinzer126
Georgia
That’s what I thought too, but the power tailgate works just fine without anything installed in Tail Gate 1 or Tail Gate 2 slots.
mkinzer126
mkinzer126
Georgia
How did you remove the big relay @mkinzer126 ? Did you just pull it straight out with force?
The brown ones in my post above? They just pull straight up / out. Just used my fingers to pull them out.
mkinzer126
mkinzer126
Georgia
My neighbor has a non-hybrid 2024 Tacoma TRD Off-Road without the premium package. I just went over and looked at his underhood passenger side fuse / relay box and he has all four brown relays installed in those four slots. Still trying to figure out what those TAIL GATE 1 and TAIL GATE 2 relays do. Still a mystery. :)
