Installed OEM front door edge weather stripping
Slappy
tacoma , highlander
mine has holes for these ,so I am gonna order both sets
hogshooter
Corey
Plant City, FL
2024 Tacoma Limited 4x4
Yes, corporate cost cutting to increase profits. The upper trims also get dual pane front window glass to reduce noise in the cabin.
That's why my Limited has a weird edge on the door window glass!
Mini2nut
Mini2nut
And desirable full time 4WD. It’s only available on the Limited trim.
Canufixit
Canu
New England
2025 sr DC 4x
I am guessing these come standard on the more premium Tacoma trims. My TRD OR without the Premium package did not have them. Hopefully they will reduce some wind noise and keep the door jambs cleaner. Each door runs around $38 and they fit perfectly as expected from an OEM part.
Once you remove the 4 factory plugs in the door the install is easy. I posted the part numbers and included a few before/after pics for anyone else that may be interested.
Do the Plugs get reused - or does the new f Door strip have them included - or need to order separate ?? I see no other clips in the parts diagram ?....
Thanks !! SteveC
Mini2nut
Mini2nut
You can discard the plastic door plugs. The new part has built in push clips.
2024 Tacoma Installed OEM front door edge weather stripping IMG_1445
Canufixit
Canu
New England
2025 sr DC 4x
Thanks. If Needed to order something i wanted to get it moving ...
Did it fit/install without ISsues??? Any Suggestions ??? Thanks Again !
Cabo
Pacific NW
2025 TRD Off-Road i-Force Max
Think I'll order all 4 pieces. But, a silly question...how to remove Rear Window "trim" piece (as seen in these pics from a poster on TacomaWorld)? Just pop up and off with trim removal tool or other??? I'm cautious about just "prying" without knowing correct procedure.
2024 Tacoma Installed OEM front door edge weather stripping 20250117_103345
2024 Tacoma Installed OEM front door edge weather stripping 20250117_102752
2024 Tacoma Installed OEM front door edge weather stripping 20250117_103135
Tamer
Sacramento, CA
I was wondering what is the part number for those parts on the 2025 4Runner? any help is appreciated.
Mini2nut
Mini2nut
Zero problems. The hardest part was snaking the weatherstripping behind the door hinges. It fit perfectly.
Canufixit
Canu
New England
2025 sr DC 4x
Hi All !!!
I have in hand my drives side gaskets F and R doors. Before I Muck up yet another easy thing ... Does anyone have the install sheets/instructions for these ??
Thanks much !!
Canufixit
Canu
New England
2025 sr DC 4x
Hi All !!! I have in hand my drives side gaskets F and R doors. Before I Muck up yet another easy thing ... Does anyone have the install sheets/instructions for these ?? Thanks much !!
