Installed OEM front door edge weather stripping
Mini2nut
I am guessing these come standard on the more premium Tacoma trims. My TRD OR without the Premium package did not have them. Hopefully they will reduce some wind noise and keep the door jambs cleaner. Each door runs around $38 and they fit perfectly as expected from an OEM part.
Once you remove the 4 factory plugs in the door the install is easy. I posted the part numbers and included a few before/after pics for anyone else that may be interested.
2024 Tacoma Installed OEM front door edge weather stripping IMG_1442
2024 Tacoma Installed OEM front door edge weather stripping IMG_1443
2024 Tacoma Installed OEM front door edge weather stripping IMG_1444
2024 Tacoma Installed OEM front door edge weather stripping IMG_1446
2024 Tacoma Installed OEM front door edge weather stripping IMG_2499
Mini2nut
Mini2nut
Yes, corporate cost cutting to increase profits. The upper trims also get dual pane front window glass to reduce noise in the cabin.
Dansflhti
Nova Scotia
I think there is another strip that goes between the front and rear door.
Mini2nut
Mini2nut
Correct. I'm trying to find the part number for that section. It’s attached with an adhesive strip, no push clips.
Tamer
Sacramento, CA
Hello,
I am trying to fit that part to my 2025 4Runner Sport. It looks like I don't have those tab on my door!!! :(
Kjc
Anc
2024 Tacoma OR
Thanks for the part numbers... Does this help with water staying out... I got the Upgraded package and missed the gaskets I guess ?
Mini2nut
Mini2nut
I installed yesterday and no rain in the forecast. I mainly purchased the product to keep out dust when Over Landing.
I also plan on installing some bulb gasket weatherstripping around the doors to help mitigate dust and noise.
Reactions: Kjc
Kjc
Anc
2024 Tacoma OR
Let us know if you find the other part number for in between the front and rear doors... I'd like to order all at the same time... Sparks parts has the fronts
Mini2nut
Mini2nut
Order placed for the front lip weatherstripping for the rear doors. They are around $18 each:
67895-AK010
67896-AK010
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Interesting, my 24 TRD Off-Road came with the door trim
Canufixit
Canu
New England
2025 sr DC 4x
I don't think I have much road noise in my SR so adding them my not help .... BUT as I live in the north, I'm thinking that these may be very helpful keeping the sand an salt out of the door jams in the Winter... ???
