RichP64
Rich
Las Cruces, NM
Finally got all my BD lights installed. Was trying to keep the lines of the truck pretty much stock while adding as much lighting to the front as possible. 4 XL 80's, a pair of S2 Pro's and a pair of Squadron Pro's.
2024 Tacoma My Custom Baja Designs Light Setup BD Lights
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
Nice job! That looks great. Do you have more details on how you modified the grill and how the grill lights are mounted?
RichP64
Rich
Las Cruces, NM
I bought an aftermarket grill, the dimensions were slightly different than the OEM and i didnā€˜t want to hack up the original. Here’s a couple pics of setting it up, i did a few additional cutouts to accommodate the camera, guess i got in too much of a hurry to photograph final and painted project. Also used a couple pieces of flat bar stock welded on the top to support the weight.
2024 Tacoma My Custom Baja Designs Light Setup IMG_4208
2024 Tacoma My Custom Baja Designs Light Setup IMG_4212
2024 Tacoma My Custom Baja Designs Light Setup IMG_4206
RichP64
Rich
Las Cruces, NM
I bought the cheapest LED Fang lights I could find on ebay (less than $50) and took them apart to harvest the part with the tabs that connect to the grill and carved out a hole for the Squadron Pro (wide cornering lens). I made the new bezel a bit wider on the outside to ride up on the lip of the harvested part so the bezel would be angled in to point the lights more forward. In hindsight I'd have placed the mounting holes a little differently, one in particular is very close to one of the mounting tabs that lock into the grill. Made from .125 aluminum.
2024 Tacoma My Custom Baja Designs Light Setup Fang 1
2024 Tacoma My Custom Baja Designs Light Setup Fang 2
2024 Tacoma My Custom Baja Designs Light Setup Fang 3
2024 Tacoma My Custom Baja Designs Light Setup Fang 4
Brent@ANParts
Brent
www.autonationparts.com
Ford Bronco
Looks great! Would really like to see some pics at night, I bet this lights up the road a ton.
slater
san diego
2024 tacoma sr5/2wd, white
You have some patients & skill, love what you did with the squadron in the fang pocket!!!
