Stop front drive shaft engagement in 4L by pulling fuse?
TriangleTom
Oklahoma City, OK
2024 Tacoma SR 6MT
Howdy all.
I'm in a bit of an odd spot. I have a few large home projects I'll be tackling in the next few months, and I'll need to be backing a dump trailer up my extremely steep driveway into my garage. And I'd prefer to do it without roasting my SR's clutch.
I figure the easiest way to do this is to find a way to put the truck in "2-Low". I know that this was a popular mod for 3rd gens with the manual transmission, but I haven't seen it done yet on the 4th gen. Now, I don't need anything as convenient as a switch in the cab, but I'd very much prefer to do this without removing the entire front drive shaft or cutting or splicing into any wires. Unfortunately, so far I haven't had any luck tracking down a definitive list of which fuses control which systems in the 4th gen.
Is this something that's even possible? Or am I on a wild goose chase?
izzy
Bay Area
How heavy is the whole setup? Can't see the clutch smoking unless the bed is filled to the brim with gravel, in which case you probably need a different truck lol
TriangleTom
Oklahoma City, OK
2024 Tacoma SR 6MT
When I'm backing it in? Empty trailer's a bit over 4000 lbs. I know the truck can handle that no problem; I towed my wife's car to the dealer a few weeks ago and it did perfectly and that was a 5000 lb tow. But, the driveway is so steep that it'll stall the truck if I try to idle up it in first, and given that I'm going to have to back a trailer in while turning I know I'm going to be feathering the clutch a lot if I do it in 2H, and I really do not want to do that.
izzy
Bay Area
I'm gonna be honest, reversing a 4000lb trailer uphill would probably smoke the AL80F automatic, or at least introduce a fking insane amount of heat into the trans from the torque converter..
TriangleTom
Oklahoma City, OK
2024 Tacoma SR 6MT
Why not leave it in 4 lo? I'd be concerned the rear diff or other components will be over-torqued.
You're putting the same load on the diffs either way, and it's not a straight shot back; I need to turn to get it in. With the transfer case and front hubs locked, that could seriously damage everything.
TriangleTom
Oklahoma City, OK
2024 Tacoma SR 6MT
Even with the front axles unlocked? I get the turn issue on concrete or asphalt.
If i understand the drivetrain correctly, the front axles lock automatically after a few turns in 4WD, and the transfer case is always locked so the front axle would be dragging on turns in reverse.
