Anyone install LoadLifter 5000 air bags yet?
Muckle
I swapped out the stock rear springs in my Tacoma for the Alldogs Offroad springs, due to added weight (skid plates, sliders) and for better performance towing off-road (about 1.75" of sag on stock rear springs when towing). While the performance when towing is perfect, I am not enjoying the harsher ride and rattling in the rear when not towing (95% of the time).
I am thinking about reverting back to the stock rear springs and installing the LoadLifter 5000 air bags. I would also install cradles to prevent tearing of the air bags during full suspension travel when off-road. Airing up/down the air bags is a nonissue for me; I always carry an air compressor with me and routinely air down when I hit trails.
Do I sound like a good candidate for this? Anyone install airbags on the 4th gen Tacoma? Or any other truck for that matter, and have positive/negative opinions?
24 TRD OR
Greg
Albuquerque
24 Tacoma TRD Off Road
I installed them. I like them a lot. My situation is similar to yours, except I don't tow, my load is on the truck. Rack, tent, coolers, overlanding stuff. But, I'm unloaded most of the time, like you. I took a trip to the white rim trail prior to putting in the airlift. I used Timbren springs and still had a lot of sag. So, I was able to return those and I got the Airlift. Bring able to control it is exactly what I wanted. Air up when needed, return to stock suspension when I don't. (Yes, I keep 5 lbs of pressure in it as the manufacturer recommended). I did install the cradles for off roading, they work perfect. I'm super satisfied with the air lift and recommend it.
Mtnbikes
Minnesota
I had the Wireless One with EZ mount installed on my Tacoma OF to eliminate sag while towing. No other modifications needed. Works perfectly. Better ride quality. The best part is I just push a button to inflate and deflate. Here is a before and after pic.
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_4773
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_4817
Muckle
Muckle
I've also been looking at that. Is it the 25980EZ model number? Where was it mounted? Would love some pictures if you can.
The air bags are being delivered today so the plan is to remove the Alldogs springs and install those today, then possibly install the wireless compressor system after the fact.
Muckle
Muckle
Great feedback, thank you for sharing. Where did you place the schrader valve?
Mtnbikes
Minnesota
Yes, that’s the model number. The compressor is mounted on driver side on the inside of the frame. Here are some pics:
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_5023
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_5022
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_6147
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_6144
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? IMG_6146
24 TRD OR
Greg
Albuquerque
I ran them through the license plate. License plate is black here in NM, so you don't really see the caps too obviously.
Muckle
Muckle
Did you use any spacers with the cradle to raise it up closer to the air bags, or no?
Mtnbikes
Minnesota
At what point are the cradles necessary? I did not install them and have had no problems as of yet. Of course, I do have some off road adventures, but nothing extreme.
24 TRD OR
Greg
Albuquerque
I did not use spacers. The cradles are needed if you are going to get suspension dangling onsn off camber situation. If the bag is fixed on both ends it would get pulled apart
2024 Tacoma Anyone install LoadLifter 5000 air bags yet? 20250716_165014
Muckle
Muckle
Removed the Alldogs springs, put the stock springs back in. Installed the Loadlifter 5000 air bags. Smooth, quiet driving experience has returned!
Will hook up the trailer this week and see how it tows, but very pleased so far.
Muckle
Muckle
Did you get the remote model?
Not yet… ;)
I’m always carrying a portable air compressor with me when I’m towing/camping, so I’ll give that a go for a while and see if I want to spend another $500 on the remote compressor.
Mtnbikes
Minnesota
Yeah. It’s a lot, but worth it. I just paid the bill and didn’t think about it. Ha!
