Wiring multiple lights to OEM AUX switches. Multiple ground question.
rptls
North Carolina
24 TRD OR Hybrid
I am newer to car electronics and am getting ready to tackle installing a light bar in the heritage grill and fang pod lights. Feel comfortable with most of it but I was curious about grounding the lights. I know I can hook both up to the same pigtail for power/oem switches but can I ground both on the 1 ground wire on the pigtail or should I just ground 1 wire there and ground the other somewhere else.
Thanks.
trailhunger
2024 TH
For wiring I dialed in ChatGPT as an electrical guide and it completely aced instructions for splicing in my trailer harness to my 3rd brake light in my GFC, guided a split switch off that GFC aux 1 interior lights to my Baja Designs trailer hitch pod light, it solved all my OE pigtail kit questions. I never phoned a friend, never called a shop or threw in the towel.
Kit is now dialed, I’m no electrician..FWIW
2024 Tacoma Wiring multiple lights to OEM AUX switches. Multiple ground question. IMG_1356
2024 Tacoma Wiring multiple lights to OEM AUX switches. Multiple ground question. IMG_0825
TFOUTS
Timothy
Northwest Florida
Ground anywhere on the frame is acceptable that includes the AUX switches
So it depends on two things: how many amps your lights draw, and the wire gauge (size) of the ground wire in the pigtail. To be on the safe side, run one to a bolt or some other ground.
rptls
North Carolina
24 TRD OR Hybrid
Thank you. I’m gonna play it safe and ground to a bolt.
mtc
24 Toyota Tacoma TRD OR
I have both my ditch lights grounded at the aux ground. Everything else got grounded elsewhere. No problems at all.
