Aftermarket mud flaps for TRD Pro?
Goshgo27
Rich
Boston
I'm also looking to replace the ridiculous flaps that came on the pro, but I'm so confused about fitment. Some sites say they fit every trim, some say the SR fitment is different but the rest aren't. Some specify hybrid vs non. So what is the case? Are the pro and TH fender flares really different than an OR? Is it the hybrid designation that changes fitment? I'm about to just cut up a floor mat and bolt it on at this point because I don't want to drop $350 on mudflaps.
what did you end up getting? I am in the same boat as you. Thanks
Tacomonkey
Geoff
J Town, NJ
TRD pro
I got Rally Armor flaps. I posted pics of my install a couple pages earlier in this thread. Rokbloks also have a set designed for the pro now
So I wanted to update this thread, I finally managed to get the rally armor flaps installed, though it was a pain and the rear drivers side still isn't perfect. Here's some pics. They look good, the black matches the fender flares and the red almost matches the paint.
The rear drivers side was the worst one. You can see how the top screw isn't really seated fully, and the foam spacer isn't sized properly IMO. Of course this was the one I originally started with and the one that gave the most trouble.
The rear passenger went on easier though I still couldn't get the top screw to grab with the included washer, so I ditched it. Note the spacer, DO NOT over tighten the screws over the foam spacers, they're not gaskets, they are there simply to fill that space.
The fronts went on ok, though I found it easier to turn the wheels towards the opposite side of the truck for access. There's this space that bothers me in the front but I'm over it, just glad to finally have something on there.
I am close to pulling the trigger - but do these flaps get close to the tire at full lock where those brackets are?
Tacomonkey
Geoff
J Town, NJ
TRD pro
Yes they are close. If you're running 35's I think you'll be rubbing. I'm on the stock setup and there's about 5/8" clearance at full lock. I really wanted a set of sliders from rekgen just for more clearance, but they haven't made a set for our trucks yet. They have them for gen 3 and they have universal sets, but I don't like the mesh section. Anyway, maybe check them out if you haven't already and are worried about clearance with the rally armors.
2024 Tacoma Aftermarket mud flaps for TRD Pro? 20251031_141533
TX-BluStreak
Houston
25' TRD Pro - Underground
It's a shame these mud guards are out of stock and 😱, they're twice as expensive as the Canadian OEM flaps. I wonder is there a way to remove the "RallyArmor" tags off of the flaps?
You can get them blacked out.
Out of stock with the supplier?
TX-BluStreak
Houston
I meant, if you were to buy them from Meraki Autoworks, they're out of stock.
They are in stock if you bought them directly from the supplier. The only difference is the $12 shipping fee from the supplier and *FREE* shipping with Meraki.
Tacomonkey
Geoff
J Town, NJ
TRD pro
Yeah they're stupid money. They do have an option with black lettering that looks pretty subtle. https://merakiautoworks.com/product...acoma-black-ur-mud-flap-w-metallic-black-logo
Definitely message Josh @MERAKIAUTOWORKS here on the site. They can save you some money. I have no affiliation, just a happy customer.
The reason I want them is they flex. Where I off-road it’s all sticks and branches and high grass. The other brands will get caught and rip off. Just a bummer that they kind of intrude on the wheel well. But I run 33s / 285s. Should be ok.
Amorak
Oklahoma
2025 Tacoma TRD Pro, undergound w/ red interior
TX-BluStreak
Houston
Very strange indeed…when you go to verify if it fits, it says 🙅🏻‍♂️ it does not. But when you scroll down the page to see what fits, it indicates it would. Very contradicting, which do you believe? 🤷🏻‍♂️
2024 Tacoma Aftermarket mud flaps for TRD Pro? IMG_7937
2024 Tacoma Aftermarket mud flaps for TRD Pro? IMG_7936
Tacomonkey
Geoff
J Town, NJ
TRD pro
Amorak
Oklahoma
Sadly I'd say that sounds about right. You may struggle like I did and end up with a half assed install on a rear flap, or you may be fine like other members here. If you want to be certain go with something like the rokbloks below. They're too big for my liking, but will certainly provide better coverage and a proper fit. https://rokblokz.com/collections/to...ilhunter4th-gen-2024-high-clearance-mud-flaps
Thanks Tacomonkey for the info. That's unfortunate, as I like the glossy but flexible look - and as a graphic designer rokbloks logo is a tad ugly (I'll be going for red accents on my Pro) :sunglasses:
Amorak
Oklahoma
I tried to install the rally armor mud flaps on my Trailhunter; there is a bolt that grazes my 285s. Not a big fan of how they mount. Will attempt to send them back.
