JayTech
Jay
2025 Toyota Tacoma TRD ORP
So as part of my build I wanted a better looking headlamp in my OR and fell in love with the 6G 4Runner TRD Pro lights with the amber DRL and dual projectors. After doing some digging I was pretty confident they would be plug and play and can now confirm they are 100% plug and play.
There is a dummy slot for the extra connector and everything mounts up in the exact same spots. You just lose the front bracket piece which I think just is an extra secure point for the fake air ducts.
Edited: You don’t have to have the lights leveled like I previously thought. The manual adjuster is just reversed on the 4Runner lamps so when I only had one installed it sat lower than the OEM lens as at 0 the OEM lens is at its highest while the 4Runner lamp is at its lowest. Once I put the second lamp in I actually prefer it this way. Having the higher number be the highest light level setting makes more sense to me.
2024 Tacoma First 4G Tacoma with 4Runner TRD PRO headlights 39772-2e45ff286cfa8d639130966a629e2252
2024 Tacoma First 4G Tacoma with 4Runner TRD PRO headlights 39773-708ee84cbf1041bdf9d928dba92803da
2024 Tacoma First 4G Tacoma with 4Runner TRD PRO headlights IMG_1983
JayTech
JayTech
Jay
What’s the price tag on this? Looks great
Tbh… a lot. Retail in Canada on these is 2k a side. Because I work for Toyota I get them cheaper so it made the swap only cost about $400 more(if that cuz tariffs) than buying and importing the AlphaRex lamps which is the only reason I pulled the trigger. Cost on them in the US might be more reasonable though. And maybe an aftermarket manufacturer will make a lamp that looks like this in the future that’s more reasonably priced.
AtYourCurb
Peoria AZ
Did you need a 4Runner wiring harness or was it plug & play with the factory Tacoma harness? I really dig the look. Nice work šŸ‘ŒšŸ¼
goin2drt
KY
So you lose one of the best functions of the OE lights in the wheel to adjust the light level AND paid a bunch to do that. Crazy times we live in.
JayTech
JayTech
Jay
What? No you don't lose that at all. The new lights just need to be properly adjusted to correct height first and then will work as intended. The aim adjusting wheel just doesn't bring them up high enough first.
JayTech
JayTech
Jay
Nope no harness is required. They use the exact same connectors between the two models. Main power plugs into the same spot, headlight levelling motor plugs in the same spot and if you have a lower trim with the halogen turn signals that connector plugs into the dummy connector on the back of the lamp.
goin2drt
KY
Gotcha. Misread that. I thought the wheel was no longer working. If is my favorite part of the lights as in winter I add sandbags to the back and my lights have to be adjusted.
JayTech
JayTech
Jay
Yea I wouldn't do this upgrade if I lost functionality of that šŸ˜…. I tow quite a lot and it really helps keep the lamps pointed where they need to be.
JayTech
JayTech
Jay
I want a set for my trd pro to go amber but I can’t justify the cost unfortunately just for Amber.
Yea they are a bit pricey of an option but there is also the AlphaRex lights which also have an amber DRL.
Benny
Jay
Oregon
Looks really great! Love the ā€œStock but Differentā€ look! Can you post the part numbers?
flgator77
St Augustine, FL
2024 Tacoma Off-Road Premium
Just searched the part numbers (thank you) and with Toyota's current 25% off sale my dealer in Florida would be $776 per side. I just ordered the TRD Pro exhaust for $475. I do like your lights...
