AlpaRex Double Tap fog lights
geonerdist
Curtis
Bozeman, MT
I have been eyeing these for a while and saw they were on sale right now. However got confused when I saw an option for a converter.
2024 Tacoma AlpaRex Double Tap fog lights 1764266898321-h
When I inquired about how to know if I need the converter....I'm pretty sure there are no 4th gen Tacomas with LED reflector headlights. I thought they were all projectors. I got the following answer from their support:
"Thank you for contacting AlphaRex USA. These fog lights are direct fit for 24-25 Toyota Tacoma without Rigid fog lights."
Therefore I believe that you need the converter on the higher level trims (TRD Pro and Trailhunter) that come with Rigid brand fog lights and the other trims do not need the converter since they do not have Rigid brand fog lights.
Just figured I'd toss my idea out there since there did not seem to be any resolution to this question here. I think I'm going to order a set without the converter for my TRD OR.
Plug and play on my TRD off-road
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Is it true plug and play like the OEM housing?
I have a set of yotatribe fogs and it has brackets that I need to add and adjust but the fit and finish is just bad.
Yep true plug and play, and you’d be hard pressed to tell the difference vs OEM. If you’re looking for something significantly brighter look elsewhere, these are brighter but not a lot.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Thanks already ordered to take advantage of BF deals. I’m not looking to blind people but I want the amber lights to help with bad weather.
geonerdist
Curtis
Bozeman, MT
So I think I did it wrong 🤣. @MT-Taco how did you adjust them? Seems to me the bumper cover has to come or I missed something given how high they are. I didn’t see anything obvious to adjust them.
No need to remove the bumper cover. You’ll need a long Phillips screw driver and a good light to see where the adjustment screw is at.
geonerdist
Curtis
Bozeman, MT
I thought there had to be a way! I’ll look harder tomorrow.
Crazy Mary’s Husband
Chester
God’s Country, USA
Quality from Guangdong province coupled with American marketing prowess.
it was said best by Huong Chang, janitor at Happy Face Manufacturing Co. in China, “每分鐘都有一個傻瓜出生”
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
I just installed mine and it is the same level as my headlights. I guess I need to adjust mine down
geonerdist
Curtis
Bozeman, MT
Went to harbor freight to get these lol
Yes those would be perfect! Once I looked in the right place it was obvious. It is indeed a long large Philips head. At least 7”. My 6” one was just slightly too short.
JayTech
Jay
2025 Toyota Tacoma TRD ORP
You can also adjust these with a 10mm socket, swivel and a long extension if you do not have a screwdriver long enough. That was how I did it. No need to use a ratchet as these are easy enough to turn with just your hand.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
The Phillips driver was not working for me. I used a flat head driver to adjust mine.
