Help me make a tire decision team! Falken Wilpeaks - 285 or 275, SL or C?
delek
2025 Tacoma SR5
This topic is getting worn out, I’m sorry. But I can’t find a thread that discusses what I’m looking for help with.
Bought some RRW 17x8 -18 RR5-H rims. Just being honest, I’ll be doing very light off roading in FL. I care more about retaining gas mileage than I do about sidewall strength, just being honest! I’m all bark, no bite.
Was planning to getting Wildpeaks in 275/70/17 C to save some weight. After looking in to it more, the 285/70/17 SL is even lighter. Sounds crazy but I think the bigger tire will be better overall for the truck’s performance.
Curious what yall think? Thanks!
Pappy
Albuquerque, NM
Going from the stock 265/70's to 285/70 (C) cost me 27 horsepower at the rear wheels (dyno'd). That means lower mpg. If you don't wheel, or haul loads (camper), I would stick with SL rated tires. The 275/70's would be a good compromise.
jsuber
juke
Jls297#40601
255/80/R17 Nitto Terra Grappler G3
2024 Tacoma Help me make a tire decision team! Falken Wilpeaks - 285 or 275, SL or C? IMG_6197
Mtnbikes
Minnesota
How do you like that tire size? I’m looking at same size (255/80/17) in a Falken Wildpeak ATw4.
Yotota
Zane
SW WA
24 TRD
Tire diameter has a larger impact to performance than tire weight.
Diameter directly affects overall gearing, while tire weight increases rotational weight which is less of an impact than most people realize...
https://hpwizard.com/rotational-inertia.html
That site provides all the math, along with calculators, to support the conclusions made. The short answer is that tire rotational weight has an equivalent mass of no more than 2lb/1lb tire mass. In the case of the tire sizes you are considering, both have equivalent mass factors of 1.87lb/1lb tire mass.
Base SR5 4X4 curb weight = 4375lb (Double Cab 4x4 Long Bed)
245/70r17 Firestone HLT weight = 29.95lb
Changing from a 29.95lb 245/70r17 to a 53.4lb 285/70r17:
Performance reduction from weight increase
(4375lb + ((53.4lb−29.95lb) x (4 tires) x (1.87)))/4375lb = 1.040 = 4.0% performance reduction
Performance reduction from diameter increase
32.8÷30.6 = 1.072 = 7.2% performance reduction
Total performance reduction
4.0% + 7.2% = 11.2% total performance reduction
Changing from a 29.95lb 245/70r17 to a 58.1lb 275/70r17:
(4375lb + ((58.1lb−29.95lb) x (4 tires) x (1.87)))/4375lb = 1.048 = 4.8% performance reduction
32.2÷30.6 = 1.052 = 5.2% performance reduction
4.8% + 5.2% = 10% total performance reduction
Long story short, either tire will decrease performance and increase fuel consumption. The heavier 275/70r17 will have slightly less of an impact than the lighter 285/70r17. Will you be able to tell the difference between the two tire options (1.2% difference)? Likely not.
Get whichever tire makes you happy. 😎
Yotota
Zane
SW WA
24 TRD
Oh, and for some tire input:
I have the LT275/70R17 C-rated AT4Ws on my Taco. They are amazing tires so far, with ~9k miles on them. I wanted an LT for occasional towing support, and sharp rock protection on unmaintained forest/logging roads.
But if I didn't have those needs, an SL tire would have been just fine. I ran SL AT3Ws on my old GX470 and they were great daily driver tires.
grizzlyoutlaw
MTN WEST
TACOMA
I have run both these tires on RRW rims:
285/70/R17 Falken Wildpeak At4W SL
285/75/R17 Falken Wildpeak AT4W C Rated
You want the SL rated tires. There was a significant MPG drop going from those to the C rated and I honestly have considered switching in the SL tires during the winter when I am not offroad as much. Also, -12 offset is super agressive on these trucks compared to previous gens. Stock is like +40-+50 so you may have a small rub going over 33s.
Also, the sidewalls on the SL Falkens are ridiculously thick for an SL
jsuber
juke
Jls297#40601
Love them. I was worried about having to use a leveling kit or a lift but fit perfectly. I drove them out a highway to Wakulla Beach road which is sand and they performed well. My speedometer has always read under compared to GPS but reads closer to speed until you get around 60 mph then it’s actually 62. These are what is called pizza cutters so they have a good stance. I have R17x 8 wheels with 25 mm factory offset. Stance is perfect. I got the black lugnuts in yesterday so I’ll fix that soon. Pattern on my tires makes little difference with road noise. I drive an SR so it’s not as well insulated as the Super Duper Xtra money in large doses series of Tacoma.
jsuber
juke
Jls297#40601
My tire size is:
LT255/80R-17 NITTO TERRA GRAPPLER G3 E
delek
2025 Tacoma SR5
Ok, here’s where I’m at currently.
Discount tire (shoutout to them. I’ve always gotten such good service from them) brought in 2 sets of tires for me, 285 Toyos and the 285 Wildpeaks.
Just checked them both out. I forgot to take photos comparing them, but I will do so when I’m back there getting everything installed, just so everyone can see the comparison side to side.
The Toyos are significantly lighter when you pick them up. Very noticeable.
The wilpeaks look awesome and have way more beef, and way more side lug. Clearly the more aggressive tire.
still waiting on the rims to arrive, they should be here today, so I’ll be making a final decision tomorrow. Most likely leaning towards the Toyota is just because it’s more economical for me personally. But there is no doubt in my mind that the wild peaks look amazing and would likely perform better off-road. One of the guys who works there has the wild peaks, and he was actually telling me that the wet traction was not very good for him.
Yotota
Zane
SW WA
24 TRD
I live in Western WA State, where the roads range from damp to soaked with standing water for 60% of the year, and slushy/snowy for probably 10% of the year.
I've ran both SL and LT Falken ATs. I've never had a wet traction issue.
If someone were having such an issue, my first question would be about their tire pressure and how they determined that pressure. It would likely be wrong.
I personally don't like Toyo tires in the PNW. They seem to work well in the hot/dry SW region. Maybe they work in Florida... Maybe not. I can't speak to that.
