2024 Tacoma TRD O/R Custom Rear Seat Delete
Redwolf1764
Griff
Billings, MT
So I’m working on my Tacoma build, I have a 2024 TRD OR Hybrid. Latest and greatest addition was this custom made rear seat delete.
My boy Dakota Bush, over at KDR Industries in Billings, MT, made this custom platform. The platform is a two piece design running on hinges for easy access to the hybrid battery. The platform has a built in L-track and retains the use of the four backseat anchor points for tying down gear. It locks to the backseat frame, has sound mat for the road noise, weatherstripping for stability, and was finished off in bedliner material for grip. This thing is stout and exactly what I wanted for my build.
If you're interested in one of them, reach out to him below. He kept all the dimensions and can reproduce it.
Dakota Bush
KDR Industries
406-861-6627
https://www.facebook.com/share/1b2p6f8UUp/?mibextid=wwXIfr
https://www.instagram.com/kdr_industries_inc?igsh=Zjg5ZWlpb2xmcGl1&utm_source=qr
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5826
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5830
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5831
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5825
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5832
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5829
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5828
2024 Tacoma 2024 Tacoma TRD O/R Custom Rear Seat Delete IMG_5827
Dirt
Greg
Eastern OR
Great photo lay out, and good info. My dogs are small so I just lay the back seat backs down and use a solid kydex sheet across the back to cover and hold items in the space available. The only thing missing from your photo's is how the upper corner of the back panel on the driver's side is secured. I am able to secure the passenger and middle of the sheet, but not that corner. How'd he do that?
drawg22
George
Iowa
2026 Tacoma TRD Pro, 2022 Lexus IS500
That looks clean! Just starting to look at something like this, but to me it looks better than the one by Goose Gear.
Yotota
SW WA
24 TRD
That looks really well built. How much does it weigh?
The ONLY thing that I would change, which you can DIY, is to cut down the excess length on the latch screws. I know you can't see them when the panel is closed but it still bothers me. 😂
Unrelated question:
Do your rear MOLLE panels fold down?
Redwolf1764
Redwolf1764
Griff
Billings, MT
Unrelated question:
This one is pretty stout. We were discussing using aluminum for the panel, but I went with 10 gauge steel for rigidity and cost. I’m sure you can cut the weight with aluminum, but it wasn’t the most important part to me and I wanted it to be extremely rigid and durable.
Yea, I noticed those bolts too. I’ll probably trim them up for aesthetic purpose.
No, the panel was from SXTH Element, it doesn’t fold down. That would be a cool feature, but with the weight I’m wanting it to be holding up when I’m done, a folding feature might cause issues.
Redwolf1764
Redwolf1764
Griff
Billings, MT
I was looking at Goose Gear too, but it was crazy expensive and because of the hybrid battery system, there wasn’t going to be much storage space. I really wanted the platform to be as low profile as possible so I could use as much space in the back as I could. The GG platform sits up pretty high off the backseat frame. To me that was just wasted space if it couldn’t be effectively used for storage.
Redwolf1764
Redwolf1764
Griff
Billings, MT
I’m pretty sure it’s just resting on the preexisting platform. It was fitted specifically, but I can look and see what was done.
myhikingboots
Chuck
Atlanta, GA
2025 Tacoma Trailhunter
Well done. I’m currently working on a seat delete for my truck and I might have to steal some of your design!
Redwolf1764
Redwolf1764
Griff
Billings, MT
The whole thing was just some ideas I had rolling around in my head. I’m sure there are ways to improve or change for different purposes, but it’s exactly what I wanted. Steal away dude and good luck with your build!
Redwolf1764
Redwolf1764
Griff
Billings, MT
I want,
But it probably insanely $$$ to ship that to Canada.
It’s definitely worth reaching out to Dakota, I would go with an aluminum build instead of 10g steel. It will help with weight and there may be a freight option 🤷🏼‍♂️
ALDube
2025 Tacoma TRAILHUNTER
I did send and e-mail already and ask for aluminum...
How hard was it to fit the SXTH Element panel since they keep mentioning it is not compatible with the jbl sound systems,
I havent order them yet.
Redwolf1764
Redwolf1764
Griff
Billings, MT
I don’t have the JBL system in my hybrid, I’ve heard from other people they will fit with the JBL it’s just a super tight squeeze. It was also a really tight squeeze for the hybrid since the back panel comes apart differently than the non-hybrid. It’s doable, just tedious.
I think it looks great once it was installed and I think it will suit my needs quite well.
Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
This is my biggest complaint about the goose gear - how high it is. I found a great deal for a 40% portion of it here on the forum so I picked it up, and eventually got the 60% portion during black friday. I'm going to end up retrofitting it and bringing it down so that it sits a lot lower. Just have to measure a few good times to make sure I Have it set where I want.
