Trailhunter looking to replace the garbage OEM tires
Blackwater
Will
Mesa AZ
Tacoma Trailhunter
I have a 2025 trailhunter and I am sick of the OEM tires. Ive had 3 leaks already and they seem poor in rain and off-road. Ive also heard that they aren't great in snow. I do a lot of trips up north where my parents live and I want decent snow performance. I have also had weird alignment issues but i'm now going to go 3rd party away from the dealership they seem to not be very helpful. They have improved a lot but it's not where id like it to be. I have 11,000 miles on the tires and I initial thought about going the Duratrac route like my old tacoma but I really don't want E-Load tires and on top of that I want thicker side walls. I don't need a massive tire 33ish is fine. I have seen a lot of people on here running the Falken AT4w's and I was thinking of doing a method 703 17" with 35mm offset and then an SL rated 285/70/17 AT4. What are yalls thoughts?
jetrex86
Ed
2024 Toyota Tacoma TRD Off Road, 2019 Toyota Corolla XSE, 2013 Scion FRS
I have the same OEM tires and wheels on my TRD OR. I don't do much off roading or travel in snow so the OEM meets my needs for now. I have seen a lot of comments and videos on how good the Falken AT4ws are off road. My suggestion would be to also look into the BFgoodrich K03s which I hear are also very exceptional. I would say either one of them should be up to meeting your needs. Good luck bud!
jackvz
Jack
richmond
2025 Tacoma Trd Pro
What are the OEM tires on the Trailhunter?
jetrex86
Ed
265/70R18 GOODYEAR TERRITORY RT
2024 Tacoma Trailhunter looking to replace the garbage OEM tires gy_wrangler_territory_rt_alt_bw_full
Blackwater
Blackwater
Will
Mesa AZ
Tacoma Trailhunter
I have looked at those but I mean the reviews on the Falken seem great especially for road noise and I like the look better. Wasnt a massive Ko2 guy either. Yeah I don't "need" new tires I want them and I think I got unlucky with mine having all the issues.
shackley
Bernalillo County, New Mexico
www.swxrflab.net
2026 Tacoma TH (Ice Cap); 2024 RAV4 Prime
I have Nokian Outpost nATs 285/70/R17 that are SL, are great in snow and rain, and in the desert as well. They are very light (ca. 46 lbs). Even the E series are only 53 lbs.
If there are 20 people responding, there will be 23 different recommendations.
Blackwater
Blackwater
Will
Mesa AZ
Tacoma Trailhunter
haha yeah thats true tires are very subjective. I think I'm going to go to a 17" rim for sure and a 285/70. I really am digging the falkens looks and the reviews. How do you like the size combo? Does it look better and its totally fine stock like that full lock even full suspension compression?
shackley
www.swxrflab.net
The diameter is about the same as the Trailhunter OEM, but wider. The Nokians are snow rated, but so are the Falkens, but much heavier.
Blackwater
Blackwater
Will
Mesa AZ
Tacoma Trailhunter
Okay so then they are close to OEM specs as far as size just a little wider and chunkier tire compared to rim. I ordered it all will be put on Feb 6th! Ill keep you all posted. Did you replace the spare?
Gampy164
Don
Indiana
2025 Toyota Tacoma Trailhunter
I have P275/70R18 (~33.2”) Toyo Open Country AT3 tires on my stock Trailhunter wheels. The tires are standard load, and they have been great this winter.
2024 Tacoma Trailhunter looking to replace the garbage OEM tires IMG_2842
Blackwater
Blackwater
Will
Mesa AZ
Tacoma Trailhunter
That is a great looking truck! Tires look good. Side note does that roof rack make any noise or wind noise?
Gampy164
Don
Indiana
Yes. Most roof racks do, but it is not as bad as what I’ve read about the original factory one.
Briscoelab
MN
25 Tacoma Trailhunter, 25 LC250
I've been very happy with the KO3 in 275/70R18. Yes, it's an E rated tire but it rides well and does great in the snow. I don't like 285 width tires in the standard "33"" size (285/70r17) for snow and wet road performance. I've always felt that width tire did better with a higher aspect ratio of a 285/75r17 or a 35x11.5R17 (falken AW4W is awesome in this size as a C load tire.. but maybe a bit too big for most people on a Tacoma).
Corn-Taco
Mark
Port Orange, FL
Gen 1 Tacoma, 2025 Trailhunter, 2021 Highlander, 2022 Corolla SE
Picked up a "new to me" trail hunter that came with these Cosmo mud tires. I'm not a mudding guy plus it had spacers which I'm not a fan of.
With so much tire noise (as loud as the which oil is best), I opted to go back to OEM size and the BFG KO3's. I'll try these and if I like them the next set will be 275/70-18's like on Gampy164's.
@Gampy164 is the fitment on the 275's ok?
2024 Tacoma Trailhunter looking to replace the garbage OEM tires taco
2024 Tacoma Trailhunter looking to replace the garbage OEM tires New tires
