P04F0 code after full tank fill up
Cabby30
CA
2024 DCLB TRD OR
Hi all,
My trucks thrown a P04F0 code.
The first time this happened was after filling up completely, then immediately going home and parking in my driveway, which is downhill. It then sat for two days. When I went to work, the truck stalled twice as I made my way to the freeway. Once I got to the freeway it stuttered a few times but then after about 15 miles truck was back to normal. The code did not actually indicate for this first instance but the driving characteristics were similar to today.
The next time was today. I filled my truck tank on the way home, truck sat overnight, downhill in my driveway and then I drove it in the evening. I noticed a few stutters while driving but it didn’t stall. Truck then threw a P04F0 code merging on the freeway. Other than it disabling the active cruise control, truck drove great for the next 3.5 hrs / 200 miles.
Googling the code:
”The P04F0 code on a Toyota indicates an "EVAP System High Pressure/Load Purge Line A Performance" issue, meaning the vehicle detects excessive pressure or restricted airflow within the emissions system, often caused by a faulty purge valve, stuck check valve, or clogged canister. It typically causes a check engine light, rough idle, or hard starting.”
I don’t top off the truck. Once it clicks, I stop fueling. Not even two clicks.
The only thing I can think of is my driveway is steep and I park facing down slope. This to me is weird but the only thing that I can think of as a potential hypothesis.
Truck is a 2024 with 28k miles.
Lastly, the code cleared after unplugging battery for 15+ mins.
Any ideas?
Andrace
2024 TRD Off-Road 6MT
Could be the driveway, but could also be a parts failure. See attached
MONITOR DESCRIPTION When pressure pulsation caused by purge VSV operation in the boost range is less than the threshold value, it is determined that a high load purge line malfunction has occurred and a DTC is stored.
Cabby30
Cabby30
CA
2024 DCLB TRD OR
Thanks for sharing this! I’ll keep monitoring the situation.
I find it hard to believe Toyota would mess up a full tank on a (steep) driveway with the amount of experience they have, but who knows. That’s the only thing that is common with the two incidents.
Reconsnake
Jake
Sacramento CA
2024 Tacoma Off Road Premium
With the truck still under factory 3 year/36k warranty, why not take it in if you see that malfunction again?
Cabby30
Cabby30
CA
2024 DCLB TRD OR
I definitely will but I had just departed on a road trip and after checking all the fluid levels, oil pressure, engine/trans temps, etc. I chose to proceed. It drove great/normal even with CEL.
EatMyTaco
Murica
2026 Tard OffRoad
When your back home, maybe park it the opposite direction in the driveway?
chasea1989
Chase
Las Vegas, NV
2024 Toyota Tacoma SR5
I've worked on plenty of toyotas with evap issues in my shop, but this is definitely a new one. My educated guess would align with someone above about it being the steep angle of the driveway (which would definitely be a design oversight), but I'll agree about trying to park it the other direction to see what happens. fuel could be creeping back up a vent line and into the canister, especially when the tank is full.
abought
Richard
Georgia
I ran into this same issue.
I filled up, parked downhill on a 30 degree incline and left for three days. I did not overfill at the pump, I stopped when the gas pump stopped. I came back to stalling and the engine turning off while idling at the stoplight. The error codes came up and I took it to the dealer service center.
The technician found gas in the purge cycle. The solution was to clear out charcoal canister and lines which had 1/4 gallon of fuel in both. It cost $361.90 in labor.
I've parked here for decades and never ran into the issue with any of my other vehicles. It could a design flaw.
My vehicle is a 2024 with 11k miles.
Pappy
Albuquerque, NM
I have not had this issue. But, I'm aware that overfilling the tank can cause issues. I also have a steep driveway (though, it's all relative). As I recall the Evap box is under the tailgate, so I back the truck up the driveway to make it higher.
Cabby30
Cabby30
CA
2024 DCLB TRD OR
Note: I have not had this issue since I started parking on the level street post fill-up.
This is simultaneously good that I figured out the root cause & bad that something as simple as parking in the driveway can affect the truck in this way.
