Truck bed power outlets - how to keep always hot
swanneemtb
Billy
Richmond
Does anyone out there know how to arrange the 12V outlet in the bed to stay hot, even when the truck engine is not running?
Thanks, Bill
The only way would be to run a new wire directly from the battery to the 12-volt outlet. I'm sure Toyota doesn't do it this way to prevent the battery from being run down to the point where it can't start the engine.
Cappaworks
2026 Tacoma TRD Off Road
Would have been really nice if the bed power was controlled by a dash switch regardless of ignition position. It can certainly be done with aftermarket stuff.
Wife bought my 24 TRD
Anthony
Aberdeen Wa
My work-around for that is to plug a jackery into the outlet that charges up while I drive and discharges to the devices I need plugged in all the time.
Yep, I am doing something similar with my Jackery too have power whenever I need it, and it lasts a lot longer than running off of the truck battery.
2024 Tacoma Truck bed power outlets - how to keep always hot 20260331_081851
swanneemtb
Billy
Richmond
Yep, that's my plan too! I was hoping someone might know a better way. This is probably the safest way, to not run the battery down.
762_NateOh
Nate
Florida Panhandle
I was excited about the inverter until I realized this limitation.
Surely there could be some logic not to discharge under 20%. Would be great for cell phones, fans, or other lowish draw appliances.
Danielc
Daniel
Lakewood, Colorado
2025 Toyota Tacoma SR5
I have an Anker version of the Jacjery that I use the same way. It's in a padded case with a zipper, and it sits between the passengers feet in the back seat, charging from the 12V outlet on the back of the console.
