Disconnecting 12V Battery on iForceMAX = Fault Codes
Benny
Jay
Oregon
Well this didn’t go well. Following recommendations of disconnecting the 12V battery before wiring lights, and after reconnecting everything the dash threw a fit. 👎 Towed to the stealership for a system reboot.
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_4886
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_4885
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_4884
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_4883
What’s your estimated bill on this? 💰💵💰💵💰
Wow! I'm glad I never disconnect the negative terminal when I trickle charge my truck like Toyota recommends.
GSPHerder
Rudy
New Mexico
2026 Tacoma TRD PRO
Did you have to pay for tow and reset?
I wonder if putting trickle charge on the jump posts on top of the engine will keep juice in the system when you swap out a dead battery?
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I got those codes after disconnecting only the neg terminal to do a lighting upgrade. I waited for 45 minutes. After eating lunch and having a patience-increasing beer, everything went back to normal. I used my XTool to look at codes, erase, run a diagnostic, and whew! No more codes.
Shrug. Being an early adopter of these newfangled little beasts of trucks can be painful. Overall I love the truck, yet am always awaiting its next surprise.
Bravada
S.E. Texas
This sucks Benny.
I've disconnected my 12v battery a dozen times now, with no ill effect. I wonder why I've gotten away with disconnecting it, and the universe punishes you.:facepalm: I wonder if there is a specific order to it. I've always disconnected the negative terminal first. How long was it disconnected? I wonder if has anything to do with Hybrid versus non.
tinkerer
Roman
San Diego CA
2025 TRD Off road I-Force
I literally had this happen today after installing the Lexland Grill and lights. I have the xmas tree lights on the dash now with no luck after disconnecting the negative battery terminal. I guess I'll see what the dealer says tomorrow. 💸💸💸💸
Benny
Benny
Jay
Oregon
ToyotaCare covered the tow (unlimited miles), 💵 Diagnostic, 💵 new 12V battery = waiting for the bill and for the truck….
Benny
Benny
Jay
Oregon
@Benny Is your truck out of the 24 month warranty that covers the battery?
I’m right at 18 months and 25K miles…
UPDATE: New battery installed and fault codes cleared by Toyota Techs. My Service Advisor made sure it was covered by ToyotaCare and provided a loaner. Did have to pay for a diagnostic.💵🤷‍♂️
The Toyota Technician said DEFINITELY DON’T DO THIS… (CaliRaised YouTube Video on wiring.)
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_0419
He said the electrical systems on the new hybrid Tacomas are very sensitive to any power interruptions .
In my set-up I plan on using a rectangular two button switch to operate my Küat DEK.
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_0420
2024 Tacoma Disconnecting 12V Battery on iForceMAX = Fault Codes IMG_4878
I am not using the pre-wired AUX switches because I am reserving them for future lighting options, and I didn’t want to use two AUX switches for the DEK lights (main & back lighting).
So I in the end I don’t know. 🤷‍♂️ It seems like people have successfully installed their own lights on the Hybrids, but after having my Taco in the shop for 5 days I’m hesitant to muck around the electrical system again. All the research I did made everything look plug-n-play. The videos all glossed over actual wiring - and no one mentioned potential issues with the hybrid systems.
If y’all have some advice I am all ears - thanks in advance!🍻
