Rising Sun 2025 Trailhunter build thread
Rising Sun
North Georgia USA
2025 Toyota Tacoma Trailhunter
I am beginning the build on my 2025 Tacoma Trailhunter long bed.
So far I've done the following:
-Decked drawer system
-Mountain Hatch tailgate cover in orange
-removed front inner fender well pieces and mud guards
-285/70r18 Falken Wild peak A/T4W Load Range C 34"
-Rear spring swap from 2026 Toyota Tundra Limited 2" rear lift
-Dobinson 15mm trim spacer added to drivers rear to help remove Taco lean
-Carista software adjustment
-White Knuckle Sliders with kickout
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7475
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7484
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7399
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7514
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7372
Rising Sun
Rising Sun
North Georgia USA
The Tundra springs added about two inches of rear lift even with the Decked system loaded with recovery gear. There was no noticeable difference in ride quality. The spring on the left is the Tundra and the right is stock Trailhunter long bed coil
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7512
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7513
How's it ride?
I've driven pickups for over years, and I think Toyota hit it out of the park with the new OR suspension. For instance, it takes washboard like no other vehicle.
Rising Sun
Rising Sun
North Georgia USA
It rides great, just like factory. I spend a lot of time on gravel forest service roads and although it gave a little bit of lift and a little extra load capacity it isn’t jittery on washboard. I can’t tell a difference in ride. My rear wheel well measurements are 24.5” on the driver rear and 25” on passenger rear when measuring from hub center to fender lip. I originally had about a 1” lean to the driver side with oem springs and with the tundra springs. I added in the Dobinson 15mm trim spacer on the driver rear upper and it brought it up 1/2”. The lean isn’t as noticeable now.
hongerrr
2024 Tacoma Trail Hunter
Are you getting any rubbing with that tire size? Am also wanting to go up in size but want to keep my TH rims like you. love the look of TH rims.
Rising Sun
Rising Sun
North Georgia USA
Zero rub with the true 34" Falken 285/70r18 when the mud flaps and crash bars are removed. I have not leveled the front but I did notice that the front came up 1/4" when I installed the Tundra rear coils. When the tires are at the point shown in my pic below (slight turning), its the closest, but never scrubs. The tires have tons of room when pointed straight.
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7192
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7193
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7207
hongerrr
Thanks for the pics !!
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
Did you install your decked system the way decked advises or improvise?
Rising Sun
Rising Sun
North Georgia USA
I opted to just cut out the small section of interfering top decking with a jigsaw. It takes one minute. The door opens easily. The chuck has plenty of room to plug and unplug and no monkeying around with the compressor control module.
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7598
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7597
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
thats what I was curious about. I've been thinking about relocating the control panel to the front of the decked system. I don't know if its possible. I also don't yet own a decked system but I think that, to me, would look and fucntion the cleanest.
Rising Sun
Rising Sun
North Georgia USA
I converted my Trailhunter intake system to the TRD PRO system using the factory parts. Its super simple and only takes a few minutes. The Toyota TRD parts are just two red silicone pieces (a cap and an elbow piece) and inlet basket and four press clips. My wife and I prefer windows down most of the time and its pretty rough on the passenger with the raised air intake sounds. I will literally only have to two small Trailhunter pieces in my drawer system and could switch it back in a few minutes. I think it would be beneficial to reinstall if I head out west or plan on traveling a lot of forest roads with a large group with huge dust clouds. I do travel gravel roads here in the south on our forest roads but don't think that the raised intake noise is worth watching my wife ride with her window up all the time. I got my stuff through BAM with the memorial day sales.
PTR03-35241-AE Taco coupling kit red
1775-AK010 Inlet basket
90467-07217 Clips
2024 Tacoma Rising Sun 2025 Trailhunter build thread IMG_7599
