Westcott Lift Kit Installed on 2024 Tacoma OR Long Bed
JED
Southern Tier NY
2015 Tacoma TRD Sport
The suspension “jewelry” arrived today. Bronze Method 703’s and Toyo Open Country AT III 285/75 R17’s in the garage.
Picking up the Bronze Oxide OR long bed Monday.
Lift Installation pre scheduled for a week from now.
I love it when a plan comes together!?
2024 Tacoma Westcott Lift Kit Installed on 2024 Tacoma OR Long Bed IMG_6715
2024 Tacoma Westcott Lift Kit Installed on 2024 Tacoma OR Long Bed image
TBax
Mazda CX-9, Volvo S60
The suspension “jeweler” arrived today. Bronze Method 703’s and Toyo Open Country AT III 285/75 R17’s in the garage.
Literally my exact plan when the time comes. Congratulations!
Reactions: JED
Drakka01
Scott
Very nice. Not doing a lift but I am waiting on my Westcott roof rack. Hoping they get it out the door soon so I can post some pics of it here.
Reactions: JED
rchrds
TN, USA
Ok, I have an 04 with 2 inch lift all around (custom UCAs and custom rear leafs) what is the purpose of these pucks? The website shows a set for the front for 2.5 inches of lift and a set for the rear with 3/4 inch lift. Help me understand the disparity.
Drakka01
Scott
My understanding is that the rear already has slightly more clearance to compensate for the compression if you load the bed up with a lot of weight. So unless you are fully loading the bed, there's already "extra" clearance for rear tires.
rchrds
TN, USA
Aha- well, that won't work for me. I load the bed heavy (1K-1.5k lbs) every time it goes out, so this probably won't work for me. Interesting though.
Drakka01
Scott
You could get it loaded up and measure your clearance front vs. back. Then you'll know for sure. It'll probably be different for the various trims and packages since suspensions aren't all the same across the Tacoma line.
JED
JED
Southern Tier NY
The pucks preload the coil springs raising the vehicle. The front is designed to lift 2.5” and rear.75” to level the truck removing most of what is referred to as rake. Preloading the coils will give the truck a slightly stiffer ride. To compensate many go to a 4 ply AT tire with a more supple side wall.
It is not the most efficient way to lift a vehicle but it is the most economical. It allows the use of the OEM shocks and coils.
I had a Toytech lift like you described on my Gen 2.
Tekoma
Michael
North Carolina
Looking forward to seeing how the bronze 703s look on Bronze Oxide. I went Bronze 318 mine and I’m very happy with how it looks.
Reactions: JED
spenticus
Spencer
Santa Cruz
2024 Tacoma TRD ORP 1998 4 Runner SR5
Dude, I’m going to be at wescott on 4/23 to have them install my lift and the exact, color/size, same tires and wheels. I got my lift in black though
Reactions: JED
JED
JED
Southern Tier NY
We’re all from different geographic locations so it shouldn’t be a case of over exposure! Still not many bronze oxides out there. I did a search a week ago with 6’ beds and found 12 in the nation. Oh, with black silver interior
spenticus
Spencer
Santa Cruz
I’m underground OR 6’ bed
QUOTE="Drakka01, post: 56866, member: 4098"]
[/QUOTE]
