key fob not working
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Did you try putting it right up against the start button?
Didn't you get 2?
Wags
Wags
Banned
Banned
PA
2024 Tacoma Off-Road Premium
  • Thread starter
  • Banned
  • #3
Yes I got 2. The one I use all the time works fine, girlfriend took the spare key worked fine all day then it just stopped working. She got it fixed by doing whatever was in the manual but no idea why it just stopped working
She read the manual.. Ask her?
Sner
Not sure if this helps - but it’s how most Toyota’s fobs work. Doubt someone is “accidentally” getting it into the battery saver mode.
jkashmire
Dallas, TX
Toyota Tacomas 3 2018
Sounds like your key fob's giving you trouble. It could be something simple like the battery running low, which happens pretty often. I’d try replacing the battery first—super easy to do, and you can usually get a replacement at any local store or online.
If that doesn’t help, maybe the fob’s gone a bit wonky over time. You can look into replacement key fob; sometimes it's quicker and cheaper than you think. You could also try reprogramming it if that’s an option with your car model. If nothing works, it might be worth heading to the dealer to have it checked out.
