Key card not working anymore.
Tacoma25
Michael
Naples,FL
Toyota Tacoma
Was working fine not sure what changed. Replaced the battery and still no dice.
Is there a way to reconnect it to the truck?
pjh21
Phil
Arcadia, CA
Tacoma 2024 TRD Sport
Mine also stopped working. My dealer said that they are not under the warranty. They attempted to fix it, charged me $12 for a battery replacement (which didn't fix it) and then told me I could order a new one. It would take 6-8 weeks to arrive and the cost was ridiculous (over $300).
gpburdell
GA
3G Tacoma
I'd get a second opinion - unless it failed due to damage I'd expect all keyfobs provided with the truck to be covered under the warranty.
And from experience with using the Lexus wallet key with my 3rd gen, when the battery gets low the truck will alert to replace the battery - which is a CR2412
828findadventure
Eric
North Carolina
2025 Toyota Tacoma SR5, 2021 Toyota Tundra SR5
It's covered if under 36k miles.
hoodouken
Las Vegas
Anyone else figure this one out? I just replaced my battery in the card and now I have to put the card to the start engine button for it to start, and now I can't lock the doors from the door handle.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Have you gone through the truck set up settings to try to reconnect to your key card?
I had to do that recently after the dealer reflashed my ECU. All of my engine control connections and customizations were wiped out. However, the multimedia customizations were mostly intact. I had to fiddle around with CarPlay again, but that was it.
gpburdell
GA
3G Tacoma
Shouldn’t need to reprogram, battery change should be seamless. Make sure new battery is good and inserted correctly. + on logo side
granted, my experience is with the Lexus card programmed to my third gen, but I’ve done a couple battery changes across nine years. Never needed anything but a good new battery
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
My keycard fob is very sensitive to voltage, and the paper thin 2412 battery seems to lose voltage quickly. My keycard fob stopped working a few weeks ago at one year of use and around 2.9 volts on the battery. I bought a "new" battery, which was showing 3.0 volts, and sometimes it would work, and most of the time it would not. I bought some actually "new" batteries, and the first one I tried had 3.3 volts, and all is good now.
NoSlushbox4Me
TX
2025 TRD Sport 6MT
Why did the dealer reflash your ECU?
lauren01
Lauren
Ventura, CA USA
My truck crapped out while driving on the freeway in the rain after a couple of hours. I made a post about it in a transmission thread while waiting a few days to hear from Toyota service tech about what happened. It was diagnosed as an electrical short. Here is the code and AI translation of that code:
P21199B (Confirmed Short)
Google AI
The Toyota Tacoma error code P21199B indicates a throttle actuator control system problem, likely a "throttle body range/performance" issue. This means the engine's computer (PCM) has detected a problem with the electronic throttle control, causing the vehicle to enter "limp mode" (reduced power) for safety. Common causes include a sticking or dirty throttle body, a faulty throttle position sensor or accelerator pedal position sensor, or problems with the throttle actuator control motor or associated wiring.
But no cause was actually found, correct. I assume you are driving it and hoping at this point, which is not very comforting.
lauren01
Lauren
Ventura, CA USA
Correctamundo. Driving with both hands on the wheel with fingers crossed is where things sit. Discomforting indeed.
