NewtoToyota
Georgia
24 TRD Sport
Just installed mine and it was a no go for me. Can’t even get the button for Mts to light up. I didn’t disconnect the battery so I will try disconnecting for a bit then reconnect and see if anything changes.
Madmez
Eddie
San diego
Rav
Did you ever get it to work?
Brooksie
Brooks
Kelowna BC
I got mine the other day and installed it. I have the TRD Sport and it would not work the MTS or crawl control. I also tried disconnecting battery. Too bad! I'll keep it and hope someone will figure out how to get it to work.
Vidman
Rick
Mass
If this works on sports why not on limited?
They are basically pretty much same on the transmission and 4X4 setting
The limited has AWD and not part time 4 wheel drive. Totally different system
Remake97
Princeton
2021 GTI, 2024 Tacoma Limited Bronze Oxide
Only hybrid limited is AWD. Non hybrid limited is same as sport except adjustable shocks.
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
Ok, I've read through all the replies in this post, am I correct that the original poster is the only person that has been able to get this to work? It sounds like a good upgrade if it really works but so far only one person???
wutheck
Jeremy
Sparks Nevada
2024 Toyota Tacoma TRD Sport
I was never able to get it to work. Tossed it on a shelf in the garage for future remedies.
I still stand by my original opinion that Toyota isn't going to simply allow a <$200 part to allow access to the MTS abilities. More than likely you need the panel + some sort of module (if the capability are only those two parts).
It was posted in another thread as an observation during an unrelated topic.
There'd be two steps to this if one brings the information together. First, changing the dial as OP did. Second, connecting to the truck via TIS software and updating the computer to activate the MTS setup itself.
Per that post software can be had for <$20 for a week's access on the European version, or $70 for the US version (can't remember if that's for a week or month). But you also need a $$$ supported ODB connector cable.
So I suspect if you really wanted to do this, you're in it for about $800 + time (dial, connector, software rental). Each person would have to decide if the feature is worth it to go after.
The manual states that the "underbody" image is a delayed replay of the front grille camera's footage, not an additional undermount camera.
Btimothy4
Btimothy4
TB
Denver
All - Nope not my eBay store, not trying to scam anyone - all I can tell you is that it did work for me. I corrected that the crawl didnt work - but MTS did
NewtoToyota
Georgia
24 TRD Sport
I was just kidding, I don't actually think it is your store although that would be a slick move.. I believe it worked for you, I am just bummed it didn't work for me. Oh well it was worth the money to give it a shot and maybe someone will figure it out sometime how to make it work for me too.
Either way I appreciate you being the first to test it out and sharing with the forum.
4_5cience
Ignacio
2024 Tacoma TRD Sport 4x4
Okay, so I tried this out and it worked!
MTS lights up and when in 4Hi or 4Lo I can change MTS settings and they actually change the trucks settings.
DAC/Crawl, does nothing.
I have a 24' TRD Sport Premium 4x4.
What would it take to make DAC/Crawl work? Given the breaking system is all electrical now, would it be a change in software only?
