So here's a hypothetical, if you have a hybrid and run out of gas what happens?
evlfred
Monte
Idaho
does it just stop like a normal ICE truck or do you have a little range?
Depends on the hybrid battery charge? Best case scenario a block or 2? But If the computer decides it wants the engine to start and it doesn’t codes will be thrown and your done.
trailhunger
2024 TH
Expect it to stop dead. The hybrid cell requires constant energizing. And if you don’t drive your hybrid for extended periods you run the risk of the NiMH going dead and that will require a tow to the dealership apparently (stated in the manual). But you have about 90 days of life in the hybrid cell w/o it being driven to recharge it.
If a hybrid vehicle runs out of fuel, the outcome depends on the design of the hybrid system. In most hybrids, particularly those with parallel or mild hybrid systems (e.g., Toyota's Hybrid Synergy Drive), the battery alone cannot sustain the vehicle for significant mileage once the fuel is depleted. The system is designed to operate with both the engine and the electric motor in coordination.
  • Parallel Hybrid Systems (like Toyota and Ford): These rely on the gasoline engine for primary propulsion, and the battery assists during low-speed driving, acceleration, and regenerative braking. If the gasoline engine runs out of fuel, the vehicle will likely shut down, even if there's some battery charge left. The electric motor in these systems is not intended to power the vehicle independently for long distances.
  • Plug-In Hybrid Systems (PHEVs): These vehicles can operate solely on battery power for extended distances (e.g., 20–50 miles) when fully charged. If you run out of fuel, a PHEV may continue to operate in electric-only mode as long as the battery has sufficient charge. However, once the battery is depleted, the vehicle will shut down.
Dataman
Randall
2001 1st Gen Toyota Tacoma
I actually happen to like the concept of electric / hybrid vehicles... Its just that the technology (IMHO) is not quite "there" yet. Its still too new and too many "gotchas" that occur in order for it to be comfortable for me. I will let others deal with all the issues that occur with electric & hybrid systems until I'm convinced its much more stable and reliable.
SonoranSurvivalist
Toyota has been making hybrids for over 2 decades now... what do you mean it's still too new? The only new thing about this platform is it's not an eCVT.
tacoboutit
2024 toyota tacoma trailhunter
Granted, my TH is still too new to judge reliability (and will be for a long time) but i love the extra kick this thing has on the low end. I was skeptical at first but now, gas only would feel like settling. But that is why options exist. Different people want different things. Everything in my vehicle is covered for 7 years, powertrain included so any issues will be resolved without me having to pay anything. No issues yet though.
The running out of fuel case is covered in the manual, but basically you don't want to do it. That will be tow truck time and you can't count on much range with just the battery. So @trailhunger is right, it won't go for long and was not designed to.
Like @SonoranSurvivalist I don't get the too new part. The first hybrid I drove was a rental Prius in the early 2000's. Toyota has hybrid tech nailed and it has proven amazingly reliable. I expected this hybrid setup to basically just be more powerful, but it is much more sophisticated than I expected.
Mine won't drive for very long on just the battery, although it does it often when I let off the gas, even at speeds of 50+ mph. It starts and stops so smoothly that I can only really tell because of the fake engine noise. Just like every Toyota hybrid I have driven it amazes me with how well it works in real world driving.
But like @tacoboutit what I love about it is the power. It feels strong like none of my V6 Tacos ever did. It isn't a full hybrid by design, but a strong powertrain that still gets decent fuel mileage. Plus its acceleration feels more effortless than the 5.7L engine in my Tundra ever did, while getting double the gas mileage. The only minus in that comparison is it never makes the glorious sounds that the 5.7L with dual exhaust did so well.
Charizard
Matt
Virginia
2024 TRD Pro - Terra
And the battery is covered for 10yr / 150k - got the lecture today when I picked up my Pro
ChrisWhaaaat
Western Canada
2024 Tacoma Trailhunter, 2018 4runner limited/turned off-road, 1977 FJ45
I am SO glad I got a gas only!
K but us hybird drivers actually have more range…. And they still take the same ā€˜gas’, same engine. And as many others have said, the hybrid tech is nearly ancient now. Toyota’s/tacomas hybrid systems aren't trying to break records for fuel efficency, but they absolutely dominate in reliability.
I agree @ChrisWhaaaat. Some Toyota hybrids like a Prius Prime or RAV4 get really good mileage - near 50 mpg - but our trucks are for power, and do that incredibly well IMO, and with no gas use penalty. The best of both worlds from my POV.
