Bed Step Question (15% off right now)
guitarist alec
Alec
california
Does anybody know if you can use the bed while the tailgate is open ?
i'm looking at getting this bed step… The one in the picture… For my 2024 Tacoma sport, long bed…
2024 Tacoma Bed Step Question (15% off right now) IMG_4824
flgator77
St Augustine, FL
2024 Tacoma Off-Road Premium
Yes, you can use the step with tailgate down. It's offset to the right. I like mine and use it.
flgator77
St Augustine, FL
Here's a pic I just snapped for reference. The grab bar is something I've had for a few years and can't recall where I purchased. I have bad knees and it's helpful.
2024 Tacoma Bed Step Question (15% off right now) IMG_3210
Tsturbo
Terry
WA State
‘24 Tacoma Limited
Yes and super easy install
Pootklopp
Usa
2024 Bronze Oxide TRD OR
Just a heads up, always check Fred Anderson Toyota parts department. They almost always run 20% off and add the seasonal discounts and free shipping on most parts. You'll see the full discount after adding to the cart and inputting shipping address!
2024 Tacoma Bed Step Question (15% off right now) Screenshot_20240906-172300
Goriders
2024 Tacoma Sport Plus
Very useful accessory. I just installed mine. It wasn’t very complicated other than not stripping the self tapping screws.
Very useful. Easy to step on the edge to pull down and easy to kick back into lifted position. When down, it sits just to the right of the open tailgate. I forget the exact numbers but in some other post 3 reported the height from step to bed and from ground to step (at least on Ltd trim).
Install is 15ish minutes, with tightening the final bolt the most annoying (can I lay access from the side, so when it tells you to install the first bolt with slack to hang on, play with getting it to as little slack as needed to save you time at the end.
100% highly recommend
bresna
2024 TRD Sport
It's not that cheap now. :)
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
Yes, I recommend not torquing the small screws into the step to the full torque that they call out. It is a bit too much.
Stebo19
So Cal
2024 Tacoma 4x4 TDR Sport Premium Pkg upgrade
I was looking at the same step but opted for this little stool that folds flat and cost $15 on Amazon.
2024 Tacoma Bed Step Question (15% off right now) stool
emerica243
Matt
PA
Fusion
Anyone know of best price for this step with now?
