Aftermarket Retractable Bed Step?
CyberTaco
Anthony
Grand Bay, AL
2025 Tacoma TRD Off Road Dual Cab, 2020 Subaru Outback Premium
Does anyone have a recommendation for an aftermarket retractable bed step? Am considering the OEM version but it is 3x the price of several aftermarket steps I have come across. Is this is buy once, cry once situation or is Toyota marking this way up and the aftermarket versions are perfectly acceptable?.
I got one from Amazon that was Brand name Aceavy, $95, and have no complaints. I've used it several times and I'm glad I bought it.
Tamer
Sacramento, CA
quick question, can a bed step be installed on a 6th Gen 4Runner 2025? I would like to install one as it helps in cleaning the roof and getting stuff put on the roof rack.
Dansflhti
Nova Scotia
I think that is true, but they should say the problem is the recovery points, because a lot of 4th gens have had them added. And what does that have to do with the trailer hitch?
I never buy stuff online when the details don't make sense, because who knows what else they have wrong?
I really like the red recovery points, but I don't have to worry about them interfering with the step I have installed. They cost nearly $800cdn...plus I'd need to buy the step adapter for probably $200cdn...ain't gonna happen..lol
Ozzy269
Lee
Timely post! While loading mulch at Lowe's yesterday, I got the comment, "Why isn't there a bed step or something to get into the bed?"
It'll be here Wednesday.
I went with one off of Amazon. I will post an update when I get it installed.
Ozzy269
Lee
Ok - so i went with an aftermarket step from amazon. I can’t say anything negative about the quality, though I did have a problem with the install. It may well have been user error. I could not get one of the three bolts that attach it to the vehicle to thread properly, kept wanting to cross the thread. I kept fiddling with it, trying to be careful and not strip anything. I played musical bolts, there are three, and eventually found one that would thread properly in the stubborn hole. I also may have had something misaligned, there was a tab. I don’t know for sure if I was hooking into the frame properly. So it may have been 100% or it may have been the truck. It may have been the bolt. I can’t say. Long story, short, too late, I eventually was able to get the bolts installed properly without forcing them. Once installed, I’m satisfied with the result. View attachment 34228 View attachment 34228
2024 Tacoma Aftermarket Retractable Bed Step? IMG_2312
TacoJay
Jay
Rockledge, Florida
2024 Toyota Tacoma TRD Sport 4X4
I bought an aftermarket step off of eBay from a private seller for around $69.00. It is solid as a rock. Also, the plastic step has the exact same imprinted "design" that matches the OEM rear bumper. I've used it for about six months now and it's solid.
Sorry, I don't know the name of the manufacturer but just wanted to let you know that there are quality alternatives (even on eBay) at a fraction of the cost of OEM.
2024 Tacoma Aftermarket Retractable Bed Step? IMG_20250405_084545
2024 Tacoma Aftermarket Retractable Bed Step? IMG_20250405_084555
FLAirgunner
Paul
NW Florida
2025 Tacoma Limited Hybrid
Here's a couple pictures of my after market Bed Step from Amazon:
2024 Tacoma Aftermarket Retractable Bed Step? IMG_5257
2024 Tacoma Aftermarket Retractable Bed Step? IMG_5258
I've been very happy with it and it seems to tuck up next to the truck a bit closer than the Bed Step I had on my 3rd Gen Taco.
djevans
Don
Tennessee
2025 Tacoma
I think I bought the cheapest one on Amazon with good reviews. It's been perfect. It has "good enough" quality, works well, doesn't rattle, and I haven't had the slightest problem.
I will add...I have a 2025 Limited with a duel tipped exhaust. This is close enough to the mounting location that I had some concern it might interfere. So you might want to consider mounting it on the right side or passenger side of the vehicle, Which is what I did.
https://www.amazon.com/your-orders/...pmentId=BfN386Dbn&packageId=1&asin=B0DQ7D7LQ1
I think it took about 30 minutes from opening the box until it was installed, best I can remember. It was very straightforward.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
I got this one off Amazon and it works great!
https://www.amazon.com/dp/B0DQ7D7LQ1?psc=1&ref_=cm_sw_r_cp_ud_ct_NWAEKE3FX1VJGXH1P3CP
Just curious, what is different about the TRD Pro's Trailer Hitch that you have to remove it to install the Bed Step? I have a Limited, it's working great on my truck.
Can attest this one works great. Installed last week. Waiting on SXTH relocation bracket, so will remove and reinstall this bed step and the ARB tow hook that we temporarily took out to try the bed step.
m1keaveli
cali
2024 offroad
i had the exact same issue installing mine..one of the bolts just would not thread on by hand.
after alot of wiggling and pushing upwards to make sure the tab was in place i was able get it bolted on giving each bolt a few turns at a time eventually. im thinking its the tab that slides into the frame that doesnt line up well.
NoSlushbox4Me
TX
2025 TRD Sport 6MT
Can this step be installed on a 2025 4Runner TRD Sport?
Do you have any pictures of the underside? In particular the area to the right of the hitch receiver?
