2.4 Rattle / Knock noise under load - does yours sound like this?
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
i went with the plain foil backed foam pads from amazon
https://www.amazon.com/dp/B09MCSZ6G7?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
and the Victory engine cover with Dynamat on underside.
They both help "somewhat"/
Great idea to add deadening material under an engine cover. Hoping clearance will be ok but perhaps spacers could be added to the cover installation brackets if needed.
I had looked into engine covers recently since having rat diners chew up my ignition coils cost me a tidy bundle…but the covers I found didn’t offer any such protection. My truck isn’t noisy since it comes with a sounding pad under the hood and has the thicker Trailhunter snobby glass. The only noise I could hear was my crying because of the rat damage.
TacoKiwi
Barry
2008 Jeep, 2014 Q5 TDI
If you put a mike under every modern car hood you would get same or similar sounds. Easiest fix is Dynamat under the hood and it can be applied everywhere so better than those sound mats from the factory. USA has to get used to 4cyl sounds. Unlikely this kiwi would complain as I grew up with 4 bangers.
TacoKiwi
Barry
My last oil change I switched to 5W-30, engine is a lot quieter now. Yes I’m aware Toyota recommends only 0W-20
I would keep the same grade but switch to a high quality oil like Amsoil. If you had engine problems and the dealer found out the change then it would be a world of hurt for your wallet.
Texas Bob
Bob
I definitely like the price of Amazon's soundproof mat compared to the one Toyota sells. Just curious, do you feel this made a noticeable difference in reducing engine noise inside the cabin? Also did the Amazon product come with clips/grommets for attaching mat to underside of hood, and did the holes in mat align with corresponding holes in underside of hood, or did you have to drill any new holes ? Sure looks much nicer than the adhesive applied square sound panels.
The Zekzoop mat in the link appears to be the same as the one I installed on my 2025 Off Road non-premium. The installation was easy with supplied fasteners and existing holes. However, I would describe any noise reduction as minimal. I still hear the clattery diesel noise at times when the engine is heavily loaded. Mine is a manual transmission so I suppose the automatics may downshift and not have the same racket as when mine is at lower revs and higher load. I do not lug my engine but I do often use moderate to heavy throttle at revs below 3000. I think that's when the marbles start bouncing around the coffee can. BTW are there still those big, steel coffee cans?
aaudiholic
Christopher
Denver
26 Tacoma 6MT
Between running 91 octane and 0w30 oil, the noise has pretty much went away on mine. I plan to keep this thing for 20 years so that’s going to be its diet.
Mercedes
ā‰ˆ39N
2026 TRD Sport "Mercedes"
To the OP's comments about sounds, yes, mine often sounds same. I haven't RPM-wise mapped out the rattle you're interested in, but I routinely hear it.
Ford's Coyote V8 has a similar noise, the "2K rattle". It happens around 1700 RPM and is loudest when the engine is cold. Many believe it's the DI pump in action. Some think it is piston slap.
Agree with others on the drivers of the noises: DI, high compression engine, if using low octane fuel and having no hood insulation. I felt a lot of what I was hearing on test drives and after taking receipt were the characteristic sounds of this engine. Still, it was kind of noisy.
The dealer I purchased from is a stone's throw from a Kwik Mart. No surprise if they gassed-up there with 87.
At second fill I was looking forward to re-up with Shell Premium. The next day and since, truck is noticeably quieter. Any power gains received and additional pre-ignition protection are welcome.
