2025 TRD OR vs Limited with mods
jduvy88
Jordan
United States
Hyundai Palisade and Honda Civic
Hey everybody,
I’m in the market for a mid-size truck, and have narrowed it down to a TRD OR (Premium) or Limited with mods. I’ll try to test drive both the hybrid and non-hybrid versions, but at this point I’m leaning towards hybrid for the extra hp/torque.
If I go with the Limited, I’ll definitely do some upgrades like full chrome delete, bigger tires, new wheels, and a lift. The main appeal to me with the Limited is the HUD. It’s not a dealbreaker with the OR not having one, but I’d prefer it.
I’ve never done off-roading before and truthfully this would be my first truck purchase. But at some point I would like to do some moderate off-roading. My son is 4 and I’d like to start taking him camping/fishing/hunting soon. But at the same time, I don’t envision myself doing hardcore rock crawling or anything like that. Just not my thing, nor do I want to potentially damage an expensive truck, lol. Probably 90% of my driving will be pavement driving. But the thought of having a rear diff is enticing. Because if I ever want to dabble more into off-roading, then that will lend itself better and give me more flexibility. But maybe the Limited would be capable enough in the off-road dept? Considering I don’t plan to do that much anyways.
I plan on test driving both trims soon. I’m sure at that point one will speak to me over the other.
But I figured some current owners may have faced a similar decision between the 2 trims. Any feedback, thoughts, suggestions or things I may not be thinking about? Is there a noticeable difference in ride quality and road noise between the two trims? I figure if there is that may be negated by the time I put bigger tires and a lift on the Limited?
From the research I’ve done, by the time I upgrade and mod the Limited, it’s probably going to cost every bit of an extra $5,000 or so? I know the mod options are endless, but ChatGPT said on average it would be about this lol. So to me, I’d basically be spending $5,000 or so just for an HUD at that point. And with no rear diff still. It’s hard for my brain to justify effectively spending that much for an HUD. When the only mod I’d do on the OR would be the wheels. At least immediately, would maybe put a lift on later on.
But since I will do mainly street driving, I’m curious if the adaptive dampers on the Limited make the ride that much better or negligible? I’m not sure if the full time 4WD is that big of a deal to me or not. But I’m not too educated on the pros/cons of it either. Any education points on the full time 4wd would be appreciated.
Any feedback at all would be great. I appreciate it!
KDubZ
Kody
Hawaii
25 Tacoma TRD Off Road Premium, 19 4Runner SR5
That was one of my other options. Unlike a lot of people these days I actually like Chrome, not much of a fan of the plastic chrome wheels they put on the Limited Tacoma but that would be an easy fix. The only thing that prevented me from getting one was that I wanted the Long Bed. The way I saw it was the TRD Off Road Premium DCLB has everything the Limited has minus the HUD, Power Steps, and the AVS suspension, If it’s the Hybrid then Full-Time 4X4. But I could get the Long Bed on the Off Road and it has Rear Locker, Stabilizer Disconnect, Multi-Terrain Select, Crawl Control, and Pre-Wired AUX Switches that the Limited doesn’t come with. If you’re planning on lifting your Tacoma then you‘re likely removing the AVS system if you get the Limited. To me the AVS system doesn’t feel much different than the other Tacoma’s, but it does give you Sport+ and Custom driver modes over the other models. As for Full-Time 4X4 its easier to use as you don’t have to worry about switching between 4X2 and 4X4 and is helpful if you live where road conditions are sub-optimal most of the time (Snowy, Muddy, Rainy). On the downside your fuel mileage will be less as you’re always driving 4 wheels and maintenance will be higher as you will have to replace all 4 tires at the same time instead of in pairs. As for Gas vs Hybrid, the higher HP, Torque and 2400 watt inverter to me wasn’t really noticeable or worth the added cost, higher future maintenance, loss of under seat storage, and lower rear seat headroom and leg room. To me the TRD Off Road Premium is the Goldilocks trim of the 4th Gen Tacoma.
goin2drt
KY
I can't help if HUD is your #1 want. Every single car we have ever had an HUD both wife and I have disabled it. To me the biggest reason to get limited and not have to pay a premium and then mod it to look like an OR would be the full time AWD.
ridetime
Oklahoma
The answers you get are mostly going to align with what the poster is driving. I have a Limited so hear is my biased opinion. AVS on the Limited is pretty amazing. Set on comfort it rides better than most body on frame trucks I have driven and that is a long list. The HUD in Toyota/Lexus vehicles is very wide, crisp, multi-colored, and has support for Google maps and Apple Maps turn by turn navigation. It is adjustable for both tilt and height. As HUD's go it's pretty good.
There are other things like laminated front driver and passenger glass, padded door cards, 14" multimedia display and a more detailed configurable main display, power rear sliding window, heated and ventilated seats, power driver and passenger seats, Premium LED lights with sequential turn signals, premium DRL's, 360 cameras, camera rear view mirror, dual zone climate controls and probably other things that I am missing that are included in the base price. Some of these things are options on the Off-Road trim and some are not. The Limited has 4x4 with low range so you can still go pretty much anywhere you want to go in a Limited.
There is no question the Off-Road has more capability on paper but ask yourself if you are going to be that one percent of off road enthusiasts that actually take their daily driver rock crawling. Even the hardest core Off-Road crowd on this forum probably spends 90-95 percent of total miles driven on paved roads. For your use case Limited all day long.
lpsoldia311
Chief
North Carolina
25 Tacoma Limited, 16 4Runner Trail
Just FYI only the MAX hybrid option has full time 4WD. My non hybrid has the regular 4wd dial selector to engage 4wd hi or lo.
To the OP I'll admit I've never owned a car with a HUD and this one is one of the factors I bought the Limited trim (on top of all the cameras/power/heated options/ rear window. Hard requirements for me and the wife especially was heated/ventilated seats but without paying 8k upgrade to premium trim to get all that, I just did a 5k upgrade to get the entire Limited option package on a truck that had sat on the lot for over 6 months. That being said the HUD sparkle has worn off, but it rides really smooth for my 90% city/highway pavement use and I'm still happy with all the power options on it.
I'd suggest the Limited unless you are definitely getting a lift, cause you'll most likely need to disable and completely remove all the AVS shocks for sure. Otherwise it'll be much easier to get an OR Trim, put all the gear and mods on it that you want and still come out ahead by just negating the HUD.
MustardTiger
TacoMAX/SDuty/Dmax
The Off Road Premium hybrid is going to have higher resale value over the Limited, guaranteed. The Limited is not a big seller where I am in Canada, and in fact...I've never even seen one in the wild. Dealers just don't bring them in. Plus, I 'd have to think the full time awd would be harder on fuel?...and the AVS shocks will be costly to replace/maintenance when the years and mileage pile on, further having a negative effect on the resale. End of the day, the HUD would not be enough to convince me to go with the Limited. You'd be losing out on MTS, locking diff, and even the available sway bar disconnect (no longer an option on the Off Road trim in Canada). Do you need all that? Probably not. But when it comes time to sell...it will most definitely broaden the appeal to potential buyers, and command a higher price.
I truly think the sweet spot truck at the top end of the Tacoma lineup, is the Off Road Premium Hybrid, with sway bar disconnect. If the TRD Pro could be optioned without the iso dynamic seats...maybe I'd change my mind...but until then, I stand by what I say. Lol.
MustardTiger
TacoMAX/SDuty/Dmax
Also, as crazy as this might sound...in Canada, after taxes (in BC):
-Trailhunter $102,400
-TRD Pro $95,600
-Off Road Premium Hybrid $81,600 (no sway bar disconnect)
-Limited $79,300
...Tundra TRD Pro $107,000
jduvy88
jduvy88
Jordan
United States
Totally agree, snd thanks for putting some of this in perspective on the resale side. I’ve driven for 22 years and have only had 3 vehicles in that time. So, I always keep my vehicles for the long term, which proves your resale point even more.
Yeah, as much as I want an HUD (have one in current vehicle), I just don’t think it makes sense to get the Limited solely for that. and then trying to turn it into a OR trim basically. I may look for some aftermarket HUDs, but not a huge deal even if there’s not a good option.
Now it’s time to go test drive some Tacomas. I’ll probably still try to test drive both trims just to be sure.
jduvy88
jduvy88
Jordan
United States
Appreciate the feedback. I think at this point I’m leaning the OR trim, but will try and test drive both trims to make sure. It’s just hard to find OR Premium and Limited trims with the hybrid system in my area. I really want to get behind the wheel of a non-hybrid, and hybrid, just to make sure I really want the hybrid. I know me, I’m a Neanderthal for extra ponies and torque, so that’s why I’m leaning hybrid. But who knows, I may find the non-hybrid is plenty. We shall see.
now the fun part begins, test drives!!
Will721
Will
Quad Cities
2025 TRD OR
I was on the fence for the same two trims for awhile too. What it came down to for me was how much of the truck I want to modify, and how much of those things are what gave the limited or off road their individuality.
The offroad is "special" because it comes with a factory diff lock, multi-terrain select, and bypass shocks stock. What makes the limited "special" is chrome, adjustable suspension, and available full time 4x4. I planned on changing suspension on either so that was a wash. I wanted the diff lock and would have to add it to the limited. I'm not a fan of chrome, so the process of removing it is an added expense. Full time 4x4 just isn't a necessity to me, especially now that shift on the fly is pretty much a standard on all 4x4s.
So mainly, I planned on removing the majority of what gives the limited it's identity and what would be left I didn't find important enough to go that direction. Not to mention in the long term the offroad would be cheaper because it was already closer to what my end goal is going to be.
jduvy88
jduvy88
Jordan
United States
agreed, I’m definitely leaning towards the OR trim. I take it that you ended up going with the OR? If so, did you get the hybrid or non-hybrid? I’m trying to setup some test drives for both, but was curious if you had any experience driving both systems. I def prefer more hp/torque, which is why right now I’m leaning towards the hybrid. Hopefully I can drive both and see which one I prefer.
lawn_wrangler
So. Illinois (STL)
2025 TRD OR (hybrid)
I recently bought a hybrid OR Premium. It is a TON of fun to drive and I haven't even had chance to take it off the road yet. But I never drove the standard OR because they had a great deal on a barely used hybrid and I jumped on it.
When you test drive it check out the back seat, especially if you're putting a car seat back there. It is TIGHT. I still have young kids (one in a booster) and they have little to no leg room (in fairness I'm coming from a minivan, so it's even more noticeable). A previous poster said the hybrid battery takes some leg room/head room from the back row, which I didn't realize--oops. Also, you lose the under seat storage. So consider those things too. Have fun!
EatMyTaco
Murica
2026 Tard OffRoad
I think it comes down to do you want AWD or 4x4? They each have their benefits and they each have their negatives.
AWD is superior on road and in poor weather (snow, ice, etc) but is less desirable offroad than a true 4x4.
Limited IIRC is AWD. Offroad I know is 4x4 (I have one).
As far as the gadgets and gizmos that the limited comes with, I can't speak to that stuff. I love my TRD OR, but its been such a long time since I've bought a new vehicle that I think the regular TRD OR is fantastically appointed but my perception is biased as I'm not used to "modern" vehicles and what they come with.
Will721
Will
Quad Cities
2025 TRD OR
I did drive both, but mabey I'm getting older but it didn't matter enough to me to justify the extra cost. With my driving style it doesn't hardly make a difference. If you're the kinda driver that's a "jack rabbit" it would make a difference. Towing heavy it would make a difference too. The primary feature of the hybrid (to me) is the high output 120v power inverter IF that is something you need and would utilize.
What made me go non hybrid was 3 factors. Non hybrids are considerably cheaper. They also have under seat storage which I utilize for tie downs and recovery gear. They are overall simpler to work on with less electrical and no hybrid battery system to service or replace, I work on my own vehicles, and plan on keeping this one forever. (I am capable of working on all of it, I'm just lazy)
Something to take into consideration too though, is a non hybrid is an OTT tune away from the same power as a hybrid. Then again, a hybrid makes more power with one of their tunes too if your a chasing numbers type.
