255 75r17 tires
CBarclay
NC
TRD OR
Hey everyone, I recently replaced my Kenda Klever r/t 285 70r17 with Kenda Klever at3 25575r17 and so far I like the results. ~15lb/tire lighter and better road handling. The Kendas seem to be great tires and kind of a sleeper brand. The listed dimensions are 32x10 but what I've found is that the contact patch is more like 30.5x8" at 35psi. Is it common for tires to be this different from factory specified dimensions?
I'm curious what others running this size have for actual dimensions. Could y'all chime in with brand and actual dimensions?
Thanks!
2024 Tacoma 255 75r17 tires IMG_0285
TacoBirdinNW
2025 DCLB SR5
I would guess because listed dimensions are usually measured at max psi ?
Looks good though!
BLtheP
TX
If you’re measuring by putting a measuring tape up against them, that is an inconclusive way of measuring tires. If you’re measuring the actual circumference of the tire and back calculating it, then it’s probably accurate.
A 255/75R17 is a nominal 32.1” and the actual dimensions of most are about 31.1”. That is how most tires are. To be half inch short beyond that wouldn’t be unheard of either.
CBarclay
CBarclay
NC
TRD OR
Thanks for that info! I had no idea but it makes sense.
Keithz24
Georgia
2024 Tacoma Off-Road
I changed from 28570R17 SL Falkens to 25575r17 C Dueler AT Ascent. The Falken tires had about 20K miles on them and had gotten loud in the cab. I have the TRD 2.5-inch lift for anyone on the fence about this size tire with a lift.
2024 Tacoma 255 75r17 tires 7b2fdd13-66a7-40c7-a0a4-3f88f0cb8998
2024 Tacoma 255 75r17 tires 8f0e8654-767c-4153-ba77-b4ee22d7eda
2024 Tacoma 255 75r17 tires cf1a82a0-66c7-42ab-9987-07580d6e85aa
395North
TRD PreRunner
CA
2025 TRD PreRunner
255/75/17 is the size I'll be going with as well. KO3 C load.
Install next weekend on stock 25 PreRunner.
Farkale
Tacoma SR5
Looks great! What’s the width and offset of those wheels? I’m currently running 255/75r17 on stock and looking to upgrade without too much poke.
Keithz24
Georgia
I know that it's a 35mm offset. Width I think is 8.5. They are the Method bead grip 703.
395North
TRD PreRunner
CA
2025 TRD PreRunner
Tires installed. Rides great and it almost feels like the gearing is better suited with these slightly taller tires. Anyway pics below:
2024 Tacoma 255 75r17 tires IMG_3831
2024 Tacoma 255 75r17 tires IMG_3832
2024 Tacoma 255 75r17 tires IMG_3839
2024 Tacoma 255 75r17 tires IMG_3840
