Type2Diabetes
JT
East
2025 TRD Pro - White
I really like what you have done OP. Looks great!
Your right the KO3 are noticeably heavier.
Took a fairly long 500 mile trip yesterday with them on, about 18.4 mpg highway/Two lane driving 80/20 mix respectively.
Stock tires on the OR was about 20.5 combined. The KO3 are still an upgrade for me in what I do with them, even if fuel economy suffers.
Tekoma
Tekoma
Michael
North Carolina
? Tuesday update!
Derped the front emblem! Was hoping to track down the black overlay from Toyota but it’s not yet available. I had a can of Plastidip laying around so decided to black it out! Five coats plus a top layer of glossifier and it turned out great! So much more stealth! The second photo nicely shows the fog lights smoked with Xpel film.
The emblem was very easy to remove without even removing the grill!
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_3180
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_3152
Tekoma
Tekoma
Michael
North Carolina
Installed the Screen Protech antiglare kit. Only the film for the 14” multimedia screen is antiglare. The kit also comes with pieces to protect instrument cluster, the hvac screen, the heat seat buttons, the blanks below (cooled seat buttons on premium package/Limited), and the 4x4 selector screen. The kit comes with everything needed to install successfully. I opted for the optional spare just in case but didn’t need it. I have it for sale in the marketplace on this forum If anyone is interested.
It took a few attempts to get the instrument cluster film centered but in the end it worked out great with no defects. It’s important to be sure you have ample spray solution both on the surface you are applying to and on the entire back surface of the film.
I am very happy with the result. I intentionally took the pic below when it was bright out so it is clear how well the antiglare works.
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_3196
ZIGGY
Greg
San Antonio
2024 Tacoma TRD OffRoad
Ok ok, I’ll trade trucks with you. ? Looks good, wheel fitment and color is spot on.
Tekoma
Tekoma
Michael
North Carolina
After seeing several posts on the forums and FB of wider offsets and excessive rock chips, I decided to have Apex Filmwerks (Apex NC) add some protection to these wide hips. He removed the small piece of PPF that came on the truck and replaced with Xpel covering the most likely impact zone
Traced to location of the film so you can see where it’s placed.
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_3900
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_3901
Tekoma
Tekoma
Michael
North Carolina
Ordered a “trail pipe” from my local dealer’s online parts site and received next day. Cost was $104. Install was easy but did require slightly jacking the back up to maneuver the old pipe out.
Happy with the clean look. Slight drone at idle but otherwise very little difference in sound.
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_4698
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_4706
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_4700
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_4699
2024 Tacoma Build Update! Bronze Oxide 2024 TRD Off Road Manual IMG_4728
Taconatron
nathan
2024 tacoma
Very tasteful upgrades. Very similar to what I’m about to do. My 6foot oxide will be here next week. Did you see what a muffler shop would cost first? 104 is not bad if you install yourself. Did you ceramic coat after the Ppf? Still debating that as well as tinting the moon roof.
Tekoma
Tekoma
Michael
North Carolina
Thanks and awesome that you have one on the way! With a newborn just arrived didn’t have time to go get quotes but my guess is $60-$100 to have one made at a local exhaust shop.
I have supplies for ceramic coat, now I need to find the time to do it!
I’m very happy with tint on the sunroof. It makes a big difference, I have the shade open far more than I would it didn’t have the additional tint.
DuckBlind
Spokane
24 Tacoma TRD OR
Time to take off the white TRD OR sticker
Landon
Denver, Colorado
Love the 318's and KO3's! I'm thinking of doing the same setup on stock suspension and curious if you ever noticed any rubbing or if you had to make any modifications to fit the tires?
Tekoma
Tekoma
Michael
North Carolina
Thanks! No rubbing noticed though I wouldn’t say I put it through all suspension compression and steering angle scenarios. I did add a 1 inch spacer, not for clearance but for less rake.
chopp9166
Kyle
loomis
tacoma
What lift do you have on your truck? You say you have a small 1” inch lift or level kit but fail to mention that in the details? So what is it??? Please advise thank you
Tekoma
Tekoma
Michael
North Carolina
Tekoma
Tekoma
Michael
North Carolina
Why did you do the upper? Vs the lower only is better option because of top strut hat issues. But thank you
yes. Since I wanted a subtle front lift and it avoids spring compressors (I installed myself).
