Check Engine light after jump start?
DeadSetMonkey
Denver, CO
Toyota GR86, Rivian R1S, Vanagon Syncro Westy
I have a Tacoma hybrid. Was sitting in rig, listening to radio, in ACC mode, about 20minutes.
The power cut out. And truck would not start. I guess I drained the 12v battery?
So. I used a portable jump starter to start engine (using terminal in fuse box). Drove around a little. Seems to start up and operate fine now since.
But.
Since then dash with multiple error lights, check engine, system malfunction indicators, instructions to contact dealer. Video attached.
I’m kinda assuming the ECU needs reset? Something simple? Possible to do this with hassle and expense of dealer visit? Or other advice? Or do I really need dealer to check it out?
Sner
Not sure why you need to worry about any expense, just take it to the dealer tell them wanings coming up on cluster. What more do they need to know ?
If it were me, I'd disconnect the battery, wait half an hour, and see if that clears the code.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
IMHO your battery may be weak. Test the battery voltage if you have a tester, or ask an auto parts store to test it. If it’s weak then you could go to a Toyota dealer to see if they’ll replace under warranty if it needs it.
Will721
Quad Cities
Theres been a few threads on various forums talking about weak and bad 12v batteries in hybrids as well as some discussion on the systems charging voltage.
That said, I would check battery voltage. A healthy battery fully charged should sit at about 12.6v. Then check charging voltage with the truck running, which should be 13.5v+. If the battery voltage is low with the truck off, disconnect the battery and put a charger on it. Let it come to full charge and test again. Alternatively, most auto parts stores have in store charging and testing for free. However they never calibrate them so if it shows bad I'd go to a different location for a second opinion before taking it up with the dealer. Obviously any low charging voltage should be brought up.
As for the warning lights, that's typical. Cars are not just an ecm anymore, but several onboad modules that are all in communication with eachother. None of them like it when voltage gets low while energized. It will throw several errors across all of them. Usually they can be reset with a battery disconnected for 30min or using a scanner.
A side note, some hybrids have a procedure for servicing the low voltage battery. The owners manual should list it under battery replacement. I've not heard of any Tacomas having issues but worth taking a quick look unless someone can confirm otherwise.
