Correct wiring for the tailgate lights?
Newtacointown
Toyota
Does any know the correct wiring for the tailgate lights? I’m trying to determine what wire is for the break light and what is the ground/neutral . I attached a photo
2024 Tacoma Correct wiring for the tailgate lights? 96F52B52-BD4C-43C6-A1A3-96F0A7C13A1C
Just grab a friend and an ohm meter. Six bits the green is the ground but it's easy to test with a meter. Once you find that, have your bud step on the brake and you're meter will show you the hot wire.
Sner
White wire with black tracer is the ground, light green is the power wire. Just realized I attached the wiring diagram for the RHS twilight, but looking at the wiring colours in your photo, that’s the LHS connector …. Either way, white/blk is ground, green is power. A power probe or a test light would give you answers too.
2024 Tacoma Correct wiring for the tailgate lights? IMG_1617
Newtacointown
Toyota
Thank you!
gofastdan
That wiring diagram is great! I've been trying to find the wiring for the 400w inverter and have yet to locate it.
Sner
I have access to Prodemand - Not a ton listed yet on Prodemand for the '24 Tacoma, but some wiring diagrams are there.
gofastdan
I'm sure they'll add more over time. If you ever notice they have the inverter wiring layout I'd love to know what it is. I've been playing with making the 400w output active all the time but the wiring is different coming out of the inverter from what it was on previous generations.
Utah
2025 Toyota Tacoma
On my 2025 Trailhunter - the WHITE wire is power & the White (black strip) is ground.
ejosesa
Joses
los angeles
tacoma off road 4x4
Does anyone know the harness type for the tail lights? I need the male and female ends. Trying to make a y harness.
