eatsomeonion
2025 Tacoma Trailhunter | 2021 4Runner ORP
My goal was to lift the rear and level the truck after adding a bunch of weight, maybe with a tiny bit of rake. Stock springs were sagging pretty bad.
After talking with Dobinsons, they recommended C59-823V. Here is what they told me:
Hybrid models will yield 1" less lift
C59-823V (55mm - 2.25") 880-1210lb Load / (30mm - 1.25") 1400-1600lb Load
Which means I should get ~1.25" of lift, pretty close to stock Trailhunter rear height.
However after installing the springs and taking some measurements, I ended up with +2.5" rake. All heights measured from center of hub to fender:
Front: 23"
Rear: 25.5"
This is with 800lbs of constant weight. When we add our usual trip gear (2 eMTBs at 50lbs each + riding and camping gear), I doubt the rear will sag enough to level out.
I hope the springs will settle a bit after some driving but I doubt it. I might throw on a Peak Suspension or Westcott Designs spacer lift up front. Wasn't planning on lifting the front but at least spacers are cheap and I can always remove them later if I add more weight to the rear.
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake 39777-c032c342c9416a2ab0394ab4360cfcd8
myhikingboots
Chuck
Atlanta, GA
I’m definitely not an expert but my understanding is that spacers are not a good idea. But you could swap out the front springs and get some more lift. Just my two cents. What are your thoughts on the Lonepeak? That is the camper I plan on getting for my long bed TH and I will be swapping out springs also. Good luck and happy travels!
Pappy
Jon
Albuquerque, NM
Interesting. When I talked with Dobinson about my truck they told me I needed the 819's. I installed the 819's, and they were a joke, so I installed 821's. Give me a break, so I installed their 1/2" spacer. OK, I can live with that, for now. I suspect the 823's are in my future, especially if I install an auxiliary fuel tank.
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake Truck-cro
eatsomeonion
I think top mount spacers (eg Peak Suspension spacer) won't affect how springs and shocks perform. They affect CV and control arm's operating angle, but I haven't heard anyone blow their CV due to 1" lift.
Heavier springs make sense if I have a front bumper and winch installed. Without weight it's going to feel stiff.
Westcott's preload collar works differently, and they claim "you retain your factory ride quality", but I don't understand how it is possible.
Though I haven't tested these myself, so real-world experience may vary.
I ordered the LP camper before they released V2 and increased price, so I got a free upgrade. IMO at old price, they are a no brainer. Complete electrical and water solutions, plus spacious interior. At current price you might want to compare it with Topo Topper, Dirtbox and Superpacific and find what suits you best.
eatsomeonion
Nice rig
Did your springs settle at all after a while?
Wife bought my 24 TRD
Anthony
Aberdeen Wa
I replaced my suspension with Total Chaos UCA’s and Full King coil over suspension and Dobson 819 rear springs. The 819's are good for my constant weight of 900 to 1000lbs in the rear.
BUT, UGH
after having PACIFIC UPFITTERS in Troutdale Oregon install a Backwoods Adventure high clearance overland bumper with a Warn 12k winch, along with a full set of RCI skid plates, and a set of 8 Diode Dynamics rock lights i have lost a lot of the control in the front, due to the 150lbs of bumper and winch.?
I will be replacing the front king coils with heavier rated ones from King.
The truck sits at 6200lbs and even now handles amazing
Before and after surgery
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake 20251118_154159
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake 20251118_154150
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake 20251117_083723
Cry_Borg
Bob
PA
'24 TRD OR Premium 6' Bed
BUT, UGH
Well, I've got a full set of RCI plates, their front bumper, and a Warn 10k winch sitting in my garage all waiting to be installed. Already have their sliders on. Have been debating whether or not I'll need to swap out the springs on my Kings -- seems I should just get it done. I've got the Dobinsons 821s in the rear and they're overkill for my needs. Might give the 819s a shot -- seems you're happy with those.
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
I remember the simpler days with my 2010 SR5...
Simple 10-pack leafs rated 500 lbs and EMU springs up front 200 lbs running 285's on 16's...
Our old Baja truck had National 10-pack leafs...
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake DSCN1635
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake DSCN0433_zpsb9defa58
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake DSCN0411_zps2e720e92
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake DSCN1629
2024 Tacoma Dobinsons C59-823V coil springs installed on Trailhunter with 800lbs constant weight, 2.5" positive rake ScannedImage-3
