Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires.
dennyvo
Portland
Tacoma 2025 TRD Sport
I’m thinking of buying Method 703 17x8.5 +35mm and 285/70/17 tires. I was wondering if anyone has that same setup. Any complications with it?
dapperdan
WI
2024 Tacoma off road
First pic is 285/70/17s on a stock off road., 2nd pic (sunset) is after I installed the all dogs springs. Never any issues with rubbing etc. Have not done anything extreme but very happy with the set up.
2024 Tacoma Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires. IMG_5557
2024 Tacoma Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires. tempImageJ4DzzA
Kjc
Anc
2024 Tacoma OR
Same setup on stock suspension... Method 703's 285 70 17... Only rubbing was the Canadian mud flaps..
Had to remove and use rokblokz
2024 Tacoma Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires. 20250613_144618
2024 Tacoma Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires. 20250613_144804
2024 Tacoma Fitment check: Method 703 17x8.5 +35mm and 285/70/17 tires. 20250613_144858
dapperdan
WI
Crazy, I swapped the little stock mud flats for the Canadian ones and no rubbing at stock height, of course nothing after spring install.
Kjc
Anc
2024 Tacoma OR
I'm running Falken At4w... Maybe tread pattern? It was the little nubs that stuck out on the front Canadian flaps... Only hit going up driveways and turning at the same time..
But enough for me to swap them
