Flush mount reverse lights possible on OEM rear bumper???
BennettH
Bennett
‘25 Tacoma Bronze Oxide
I understand there are options for hitch mounts, ARB bumpers and bracket mounts (below bumper) from several companies.
Curious if anyone has cut into the rear bumper and installed a flush mount reverse kit. It seems like a really tight fit and may not work given how the two bumper panels are connected via plastic clips. May also be a depth issue?
Ideally a flush mount reverse light w/brake and aux switch connection would be awesome.
Otherwise, its hitch or bracket mounts...
Cheers
Will721
Will
Quad Cities
2025 TRD OR
There's always those flush hitch lights from DD too. Unless your hooking a trailer at night it works perfectly. Plus once the trailers hooked any lighting is pretty much blocked anyway so it's not that big of a deal that it has to be removed before towing. That's what I plan on running.
