GTBradley
Brad
Denver
I ran the power wires to the 12 volt power port terminals and the antenna cord under the carpet back towards the backseat so I can mount the fiberglass antenna mast on my mid-height bed rack.
After installation, I found that all it takes to remove the base unit from the bracket or unplug the antenna is removing the four bolts in the console cubby and reaching under from the back.
GTBradley
Brad
Denver
I found a very convenient grommet right where I needed to get the antenna cable out of the cab. It’s right in of the battery vent filter. The rest of the install went very smoothly. I bought a rotating, folding bracket for cheap on Amazon and it works perfectly for lowering the mast and has the ability to fold backwards if it gets hit really hard from the front.
Midland’s instructions say to not mount the base above the roofline and I just made it with the additional bracket.
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1586
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1587
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1591
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1589
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1597
Lawrence, KS
2025 Tacoma TRD-OR
I installed the MXT275 under the armrest console and a fiberglass mast 3.1dB antenna to my bed rack. I bought the MXT275BBM bundle for it’s performance in wooded/mountainous terrain and its compact size. When I got the center console removed I found plenty of space to mount it though that metal bracket is very thick and stainless steel I think, so I used velcro instead of screws.
I copied your install this morning and I gotta say it was by far the easiest radio install I've ever done. I am curious how you ran your power though. I pretty much just ran the wiring under the console up to the front 12v outlet. The entire set up is pretty much hidden. Thanks for the tips.
GTBradley
Brad
Denver
Sure thing. Yeah, I did the same with power wires. They are spliced into the 12V port wires and considering the unit only pulls an amp and a half the draw will me minimal on the 10A power port circuit.
PS. I spent most of my life in KC. Rock Chalk!
GTBradley
Brad
Denver
I finished my GMRS radio install and I'm very satisfied with the professional look. It's clean, convenient and unobtrusive.
The RJ45 socket I bought on Ebay has its own backlight. I discovered that attaching the RJ45 light wires to the backlight of the OEM switches next to it provided 12 volts and made the RJ45 light much brighter and more blue than the others. What I did instead, was use the power from the Midland USB-C port, which provides 5 volts. This reduced the light to appear similar to the other switches and it doubles as a power indicator for the radio.
12 volts: (note: STABI BAR button is off because I'm tapping power from it).
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1610
5 volts:
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1609
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1620
2024 Tacoma HAM and GMRS Radio Installs in 4th gen Tacoma -- Post Your Setups IMG_1622
T24A-FTS
Sudhir
B.C.
2024 Tacoma Sport+ DCSB
West Mobile makes a bracket for the drivers side fender. Model: ATTTA24. I'm guessing this is a new item as I've been searching and visiting this post for months. I just got mine Friday so I haven't had a chance to install it yet but I just thought I'd let you all know.
TanComa
Tacoma TRD Offroad
Do you have the factory inverter? I read somewhere else that those of us with the inverter don’t have this empty space underneath the console. In any case I’ll find out soon enough when I start the install later this week.
GTBradley
Brad
Denver
I do, yes.
Voodoo452
Northern Nevada
2024 Tacoma TRD Pro
finally got all the pieces to install my Midland MXT575. I ended up putting it under the passenger seat, and running power through the passenger firewall as @Romer suggested. I routed the antenna to the back seat, so I can store it under the seat when not in use. Eventually I'll get a permanent mount for it. I used an RJ45 block I got off of eBay. It matches the rest of the switches in the center console very well.
I eventually want to get the Midland MXTA25 Ghost Antenna and permanently mount it somewhere, but I'll do that later.
Damn, I like that idea...
