gofastdan
I installed multiple things at the same time so figured I'd just create a single post for it all.
I purchased this "heritage grill" that came with raptor lights and light bar. When I bought it, it was $215, which I thought was an excellent deal. I swear the vast majority of these products are exactly the same regardless of what the sticker says on the box. I knew the light bar would be junk but for the money I'll deal with it for awhile. One thing to note is that the light bar opening is not the same as the factory Tacoma grill and will only fit an ~18" light. I think the current DD Stage Series 18" will fit with a little filing and my plan is to upgrade to that at some point before they discontinue it next year in favor of the new "standard" 20" bar. I don't think it will be a straightforward swap but I'll figure it out... The grill itself is nice and although not quite the quality of the factory stuff unless you really inspect it most people would never know the difference.
I installed "fang" lights at the same time. Again, I'm satisfied with the quality for the price I paid ($80). I wish they had a bit of a smoke tint to them. They don't quite match everything else but they're close. I was a bit concerned that with all the lights and whatnot going on that the front end of the truck would be gaudy (cheesy and cheap?), and some might think that's the case, but I'm happy with it and that's all that matters.
There are lots of install videos on Youtube for the grill so I'm not going to try and cover the install. This video by Taco Vinyl is installing the identical grill and once you have the front end off the fang lights are self-explanatory.
Here are some pictures.
The grill was well packaged. The raptor lights were preinstalled but you have to install the lettering and light bar. Easy peasy... Note it has a knock out for a front camera (which I don't have). :eek:( A future project to install a camera will happen at some point once there's a solution on the market...
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241202_210112481
The grill put together.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241202_213645906
Front End off the truck.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241206_192923751
Wiring for the fang light turn signal, driver's side.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241209_191726550
Wiring for the fang light turn signal, passenger's side. Note that the wiring is the same for both sides other than the fact that the wires are different colors on the driver vs. passenger side.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241209_194245115
Completed install.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241206_215912643
Ok, here's where I took a different path. With all the different lighting and whatnot that I have going on I decided I needed a better power distribution system than just trying to use the three factory aux switches. After a bunch of research I purchased this. It has 12 circuits supporting a total of 100 amps. Again, this unit appears identical (as near as I can tell) to a half dozen other products, including the MicTuning P1s. The only spin Joyutus (?) puts on their kit is that they seem to be marketing towards the Jeep crowd so they include an extra bracket that mounts to the fender of a JL and an included install page for the Jeep. Other than that there is no branding on it at all. The wireless controller is nice and eliminates having to run a wire through the firewall. I also haven't really found anywhere inside the truck that is ideal for mounting a controller, but with the wireless controller I don't really need it mounted. The wireless controller isn't perfect. For instance it's not full-duplex, meaning the controller is sending a signal to the wired panel but it doesn't know if the panel doesn't acknowledge the signal. Ideally when I turn the truck off I'd like the panel to get a signal sent to it that the wired panel had power removed and the controller should shut down and go into a low power mode, and then when the ignition is turned on the wired panel would send a signal to wake the wireless back up and restore the previous state. That doesn't happen so you have to remember to power off the controller when you shut the truck off and turn it back on after starting the truck. Realistically though, the wired panels from Auxbeam, MicTuning, etc... function the same way, they don't automatically turn on after ignition you have to power them manually. All that said, again, for the money I think this is an excellent solution.
Anyway, here's the install.
All the parts that come with the kit.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241208_200013785
I chose to mount it on the passenger side fuse panel cover next to the battery.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241209_192005804.MP
I used the IGN circuit on the driver's side fuse box to trigger the unit on and off. Note that you need to ensure the fuse tap is installed correctly. There was a picture in another thread of someone who installed the fuse tap the opposite of how I have it. That would be wrong. Installing the tap backwards doesn't protect anything. If the fuse blows power will still be flowing to whatever device is being powered and potentially cause big problems. When I read the other post at the time I didn't think anything of it but once I installed my own I realized the mistake. I've searched to find that post again and of course now I can't find it. Bottom line the easiest way to ensure the tap is installed correctly is to pull the fuse and ensure the feed loses power. If it doesn't then the tap need to be reversed.
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241208_232443012
Wiring inside the power distribution panel. I have lots of room for more circuits....
2024 Tacoma "Heritage Grill" w/Raptor Lights and Light Bar, Fang Lights and Power Distribution Install PXL_20241209_192019863
And finally, here's a video of all the different lighting effects. I've also got the ditch Lights wired into the PDU. Like I said, I'll likely switch out the cheap light bar at some point. The only other lighting change to the front might be to replace the factory fog lights with the new DD Stage Series lights that they announced at SEMA this year. I'll abandon the factory wiring and run them through this as well so I can have the fog lights on one circuit and the backlighting on another.
Great White North
Glenn
Alberta, Canada
TRD Off-Road Premium 2024 Tacoma, 2018 Rav4 Toyota
Thanks for this post. I have been waiting for a couple months for someone to provide detailed wiring instructions for such a light system on the new Tacoma. Great resource. Did you create a Youtube post of the entire installation?
UndergroundTRD
Beaumont, CA
24’ Tacoma TRD Off Road
Completed install.
Nice write up. I need to add a ground distribution block to my set up. Currently all accessories are tied into the negative terminal. I like the circuit breaker add on.
gofastdan
gofastdan
What you see is all I did. It's not difficult though. The hardest part is usually deciding how to run the wiring to make it look decent and I know I'm not the best at that. The new solid state power distribution modules are pretty sweet though. They're cheap and easy to set up. Just run the power and ground cables to the battery and run a wire to a ignition trigger and you're done (maybe run a cable for the controller through the firewall). Then all your accessories just run to the distribution panel. Easy peasy. That might be a bit of oversimplification but it's really not hard.
I'm not sure if it would affect anything with your distribution module, but I have seen a couple people that have wired their fang lights to the IGN say that it will randomly turn on when the truck is off. Just something to be aware of.
gofastdan
gofastdan
Yes, thanks. I saw that in a couple of different threads and tried to find a different fuse to tap but couldn't come up with anything. It would have been ideal to find a switched fuse in the passenger side fuse box but it seems like that whole box is constantly powered. Realistically though the intermittent power coming on doesn't affect the pdu, and if anything is a good reason to have it. The ignition tap doesn't actually power the pdu, the pdu just won't power on unless the tap is live. Once you have power from the ignition you still have to power the pdu on with the remote so I don't have to worry about the lights and whatnot randomly coming on like you do when you just have a relay straight to the battery.
Slightly different thought but the pdu also has an option to be constantly powered w/o the ignition on. There's a switch on the panel that disables the ignition tap and then it's always powered straight from the battery and you have to physically turn it on and off using the remote. That might work well in some applications but I chose not to go that route b/c knowing me it would only be a matter of time before I left something on and drained the battery.
Suzay
Hawaii
2024 Tacoma sport
Completed install.
I love the outcome and the full set up and instructions. I too wired my fang lights into the ign fuse, the correct way, but notice when truck is off the lights randomly come on. I was told that the evap system was doing checks throughout the night
gofastdan
gofastdan
I'm sure it has to be something along those lines but it's odd that the whole system fires up. In any event you could always install a physical switch for the lights but I realize that's a hassle and takes away the whole reason for wiring to the ignition circuit to start with...
Suzay
Hawaii
2024 Tacoma sport
The truck doesn’t fire up completely. It “silently” does the evap test but somehow it’s connected to the inj and ign fuses
goin2drt
KY
Great write up. I don't care much for the Fang lights but that is what is awesome about these trucks. Folks can make them their way and who really cares what others think.
Congrats on the install.
Delta1Seven
Thanks for the write up. I just ordered the Heritage Grill from Toyota.
I have a Limited so my truck has the front camera. I read another thread here that there where some weird quirks with the front camera bracket, something about it mounts upside down so you need to get a different bracket etc etc. I still need to look into that part haha
gofastdan
gofastdan
You can 3D print your own bracket if you have a printer (there's a file to download in one of these threads somewhere) or you can buy one from a company like Rave. They sell the parts here... Their install video is very well done as well. They talk about the camera starting around the 9:20 mark.
Delta1Seven
Thanks, yes I have a 3d printer so I will print myself. I saw that post of the bracket on here. The originally poster said you technically are supposed to flip the camera using a different bracket, and then need to reprogram your ECU to accept the flipped orientation. (he mentioned if you don't do this, you the camera view is slightly distorted). I won't be reprogramming so hopefully it's not too bad!
