How to reduce the engine noise on 2024+ Tacoma?
Lexland_Official
Devin
Tacoma TRD Sport
Today,we are going to introduce the front engine cover hood sound heat insulation pad mat,specially designed for the 2024+ Tacoma!
5 in 1 protection:
- Reduce Engine Noise
- Block Heat Transfer
- Vibration Control
- Flame Resistance
- Easy Installation
This hood insulation pad is precision-shaped to match the factory hood structure, providing full coverage and enhanced heat protection.
Get yours here: https://lexland.com/azjeox
Use code: Tacoma4G (20% off sitewide)
drax
2026 Tacoma SR5
I was going to order one, but I think it will prevent some of the engine heat from escaping. The turbo probably creates extra heat. Maybe Toyota designed the hood without the pad for a reason?
Will721
Quad Cities
The under hood pad is actually factory on some Tacomas, just not all. Limiteds all got one for example. It's a cost saving thing.
drax
2026 Tacoma SR5
Ahhh! I should’ve done a little research before posting my comment. Sorry!
djevans
Don
Tennessee
2025 Tacoma
I was going to write the same thing. My limited came with a hood pad installed from the factory. I was kind of wondering, why people who want a quieter engine to just order that from the factory?
GaryP
Gary
Ovilla, TX
2026 Tacoma TRD Sport
5 in 1 protection:
- Vibration Control
- Flame Resistance
- Easy Installation
This Lexland product looks very similar to OEM hood insulation sold by Toyota. Curious if there was a noticeable difference of engine noise inside the cabin after you installed it ? There's also one being sold on Amazon (by Zekzoop Store) for around $75 that looks identical, but not sure if both have the same sound absorbing qualities.
Ironhide
Lodi, Ca
‘24 SR5
My SR5 came without a hood pad. After driving the truck for a while I started to hyper-focus on the engine noise. Installed this exact style pad and it made quite a difference. Keep in mind, the market (Amazon) is flooded with this exact pad, just rebranded for different sellers. If the noise is a concern and you can find this pad for a fair price, it’s worth it in my opinion. I think I paid just over $60. Mine has been installed for about a year. Looks like new and is holding its shape.
FarmHand357
Lowell
Illinois
2026 Underground Tacoma TRD Off-Road with manual transmission
As someone mechanically challenged at times, how difficult is this actual install? Does it custom fit and easily just snap into place like the video shows?
Also, as was asked above, is there truly a significant reduction in engine noise inside the cabin after installation? Thanks in advance for any info...
395North
TRD PreRunner
CA
2025 TRD PreRunner
I bought the OEM Toyota hood insulator and if this one does the same or similar in noise suppression, skip it. The OEM barely moved the noise needle.
395North
TRD PreRunner
CA
2025 TRD PreRunner
User name doesn't check out but, if the installation is anything like the OEM version Helen Keller could do it. Very easy, 2 min job.
