Purchasing additional TPMS Sensors ?
bking
Bernie
2024 Tacoma TRD Offroad
Has anyone bought a 2nd set of Tires/Wheels for their Tacoma yet? Did the shop have the TPMS sensor that would read or do I need to get them from Toyota?
Supertech1
Arkansas
2024 Tacoma TRD ORP
I’ve been wondering the same. With the 4thGen Tacoma sharing a lot of similarities to the 3rd Gen Tundra, I wonder if they use same TPMS sensors?
paradizecityz
TX
2022 Toyota Tundra
Why not transfer from OEM wheels to new wheels? That's what I've always done
bking
bking
Bernie
Because I’m getting different wheels along with the tires. I want to keep the OEM wheels and tires together.
SleepyBear
2024 Tacoma, TRD Off Road 4x4
Toyota thought about you ahead of time and accommodates tire sets.
2024 Tacoma Purchasing additional TPMS Sensors ? IMG_0290
bking
bking
Bernie
Yes, thanks I saw that. Very cool. Now, do 2023 sensors work?
Sner
While I have no knowledge for sure, I suspect yes. TPMS works in one of two RFID frequencies. 315mhz and 433mhz. All that said, this isnt a big deal anymore, there Are several aftermarket TPMS systems that can work on both frequencies once programmed. Toyota has in recent years mainly used 315mhz for their product line as a whole, fairly certain it’ll be the same.
Supertech1
Arkansas
2024 Tacoma TRD ORP
I’ve got an extra set of TPMS from 2022 Tundra that I plan to use. According to what you’re saying, these should work, correct?
Sner
Yes, I believe so. Generally manufacturers have one sensor they use across most of the product line. It’s not always the case, but mostly is.
Discount Tire
Arizona, USA
All Things Toyota
Universal, programable sensors should be able to be cloned to your factory TPMS sensors allowing you to switch between the two sets. To be sure, factory Toyota sensors would be a definite yes, but more expensive.
JED
Jeff
Southern Tier NY
2015 Tacoma TRD Sport
I'm not seeing a definitive answer to your question but thought I'd share this:
  • I've spoken with the parts counter and part numbers do not match Gen 3 TPMS and the parts manager suggested that they are likely not compatible. 2024 sensors are available for $100 each.
  • I made some assumptions when I went after-market wheels on my Gen 2. Discount Tire sent TPMS in mounted and balanced tires that did not work and could not be synchronized. Turns out Toyota TPMS require specific after-market sensors. I burned through a set of tires before correcting the situation.
I'm planning on breaking down and using the 2024 OEM wheelset to use those factory TPMS unless someone can share the successful use of after-market or previous Gen sensors. My thoughts.
Dansflhti
Nova Scotia
On my 2022 I cloned a set of Autel sensors and they worked perfectly for 2 winters so far. I'll be keeping an eye on the 2024 sensor situation for my in-coming 24 Sport +.
bking
bking
Bernie
There are people on this site that have bought additional wheels and tires. I'm hoping one of them will chime in. The '24 will have a different part number, but I think all Toyotas have used the same frequency for some time.
BTF
Bob
St. Louis
2018 GMC Sierra
Yes - for ā€˜24 TRD Sport - Kept the same stock sizes for both wheels & tires. Switched to: 18ā€ Falken Wildpeak A/T4W 365/65R/18 tires and went with Black Rhino Raid 18x9.5-18 wheels. The Black Rhino TPMS sensors were available direct from BR. This took place last week.
2024 Tacoma Purchasing additional TPMS Sensors ? IMG_3572
dapperdan
WI
2024 Tacoma off road
Ok so if anyone is wondering here is the part number for the factory TPMS:
42607-0E090
Should be an exact fit as I just dropped them off and my wheels tires should be ready tomorrow. Now to get truck from being tinted and get them installed. Should all be wrapped up by this weekend I am hoping.
