Quick question for those using an Add-A-Fuse in the engine bay fuse box.
Mabett
LA
www.facebook.com
2026 Tacoma TRD Sport
2024 Tacoma Quick question for those using an Add-A-Fuse in the engine bay fuse box. screenshot-20260608-182133
How are you getting the cover back on with the wire coming out?
Did you cut a notch in the cover, run the wire through a gap, use a fuse box riser, or find another solution?
Would love to see some photos of how you did it.
Mabett
Mabett
LA
www.facebook.com
spyderdrifter
Tom
somewhere in CO
2025 Limited
I now have an additional fuse/relay box for auxiliary items. Prior to that I just ran wires out the bottom of the oem fuse box as I knew I'd eventually upgrade the system and didn't want to cut/drill anything.
Will721
Quad Cities
If your looking for a product idea, its out there already. If you hop on TacomaLifestyle's website they make a fuse cover thats prenotched so you can run wires through it for fuse taps while minimizing dust. Even have little covers for non-utilized slots.
Mabett
Mabett
LA
www.facebook.com
thanks for sharing this.:like:
Mabett
Mabett
LA
www.facebook.com
Yes, we noticed that. Its a clever box but the $$ might put some owners off
Wife bought my 24 TRD
Anthony
Aberdeen Wa
I chose to take the fuse box on the driver's side ( non hybrid ), loose and ran the tap wire through the factory loom. The process takes a bit longer but the end result appears factory.
A picture would be futile because it shows nothing but a fuse tap, that's the idea !
Mabett
Mabett
LA
www.facebook.com
Thanks, that definitely sounds like one of the cleaner OEM-style solutions. A few others have also mentioned loosening the driver-side or passenger-side fuse box and routing the tap wire through the factory loom. Our main concern is that it adds too much additional labor time.
Mabett
Mabett
LA
www.facebook.com
I used a small grommet. Fit perfectly and seals the hole.
Thanks! This is probably the best solution we've seen so far. Simple, clean, and keeps everything protected. Really appreciate you sharing the photos.
Mabett
Mabett
LA
www.facebook.com
