Winter time, weight in bed
aldead
Michigan
Have a 26 Tacoma SR5 4x4 all stock and live in Michigan. Looking to hear how much weight do people put in their bed during the winter months living in states that get snow.
Dirt
Greg
Eastern OR
About 180 lbs, but a buddy uses an 800 lb hay bale. Like Kurtis says, the tires make a big difference.
theKurt
Kurtis
Calgary, Canada
2024 Tacoma Sport+ 6M
I have a 24 sport, and I only have an "emergency kit" in a pelican case back there. Maybe 80lbs of straps, chains and duct tape. I've had very few issues with the back sliding in my Alberta winter, and if I do, I just put it in 4wd. The traction control is quite good IMO and your tires make a big difference. That being said, the sport has springs and not the leafs of the SR5, which may or may not have an effect. I used to rent a lot of full size trucks and SUVs for my old job to go to remote oil fields, and I always found the leaf spring trucks to be more 'lively', and I had a Dakota many years ago that was a handful. 3rd gen guys might have a better experiences with what to do.
crepr12
NEast
2025 Limited Hybrid
I have never added weight to the bed during the winter months....your truck do you
bigbunk62
Bill
Massachusetts
2025 SR5 2012 SR5
I haven't added weight since I switched to the 4x4 '25, it was fine last winter.
I used to add 140 lbs of Tidy Cat litter in four plastic buckets to my '12 2WD with Yokohama Geolandar tires all around, never got stuck with that setup. Come March,, we would then use it for the cat.
OminousSkitter
Alaska
I add three bags of traction gravel. Has the benefit of having gravel on hand if I ever need it.
Will721
Will
Quad Cities
2025 TRD OR
In the past I have done the same with salt. As long as you can keep the water and snow off of it, there's nothing better than a course rock salt for weight. If you get stuck you can always toss some under the wheels. Plus most people are buying it anyway for driveways and paths.
