socotaco
NorCal
26 TRD OR
I have been meaning to post a write up of the built in compressor installation I completed earlier in the year and hopefully this is useful or provides inspiration.
Some initial design considerations
I am in the process of building my TRD OR into a lightweight overloading machine, as opposed to a heavy duty rock crawler, so I am not expecting to have tires any larger than 33-34 inches to keep weight down. When considering how best to deflate and inflate these tires for off roading, this would involve going from hot pressures of ~35psi to 15-20psi. Sticking with the standard Schrader valves and TPMS seems sensible, at least for now, and I also do not want to remove the valve cores each time as they are not designed for this and this increases potential failures.
The maximum airflow rate that is possible through a standard Schrader valve stem is approximately 1.6cfm at 30psi and ~2cfm at 50psi, so any choice of compressor, air lines and connectors would need to match this flow to minimize any inflation time. Providing more cfm than this, without an air tank, creates back pressure to the compressor and reduces its life expectancy over time.
On a 4th gen Tacoma there are several potential in vehicle mounting locations for a compressor which do not compromise regular storage space. Most portable compressors of suitable power require connections to the battery terminals and these could be re-wired to make use of the 7-pin trailer connection to avoid lifting the hood as Viair have done with their 88P model. There are also some slightly lower power models with integrated batteries. However, all these portable solutions take up storage space, so integrating was the way forward.
A (very) brief survey of onboard compressors
Perhaps the obvious starting point was Toyota’s built in compressor system that is available as a kit (part number PT949-35241) which can be had for ~$950 on sale. The electronic pressure control and the ability to inflate and deflate was attractive, but based on forum information, the compressor is a single piston NSV model which has received some feedback on being slow. It is still surprising to me that Toyota did not work with ARB on their built in compressor, given all the other ARB parts on the accessory list.
Viair receives good reviews and has a wide range of options, but it is hard to ignore ARB’s offerings that are considered the gold standard of compressors. What was especially interesting to me was that their new brushless single had 30% more output and more importantly supported a 100% duty cycle. The only negative I was able to find about the new brushless compressors was that they run hot.
Here is a quick comparison of the different ARB units:
Brushed Single (CKMA12): 2.34cfm @ 29psi, 50% duty cycle, 7.7lbs, ~$360
Brushless Single (CKBLA12): 3.1cfm @ 29psi, 100% duty cycle, 9.5lbs, ~$550
Brushed Twin (CKMTA12): 4.68cfm @ 29psi, 100% duty cycle, 17.4lbs, ~$660
Brushed Twin (CKBLTA12): 6.2cfm @ 29psi, 100% duty cycle, 15.8lbs, ~$950
Other items needed for the installation would add approximately $60, not including any mounting hardware. ARB also offers an electronic pressure control add-on that uses a mobile phone to set pressure etc.
Thus using a twin compressor really forces all four tires to be inflated together, which I did not want to do and based on my overall goals for my truck, I decided on the ARB brushless single, and maybe I’ll add the pressure control at a later date.
Mounting location
Engine Bay - there are several companies offering mounting brackets and Youtube videos showing how to mount the compressor. It’s all in the engine bay, making wiring easy, connecting into an Aux switch, and the air connector can be mounted around the front grill for connection without lifting the hood.
Under Seat - very popular with the Jeep community, but with the electric front seats in a Taco, this would fit, but require a more complex wiring job and would limit the lower range of seat movement, and I typically have my seat set to the lowest level. Good for cleanliness here though.
Bed Mounting - the Toyota compressor is mounted in the rear driver’s side area. This requires the bed to be cut, but there is a lot of space between the bed and the body work behind the rear wheel. On the other side of the bed there is the small storage cubby, so the bed has a suitable hole and captive rivnuts are already in place. In my experience, the storage box is largely useless as it is small and fills up with dust when off-roading, so losing it would not be an issue.
I decided that utilizing the bed mounting area was most efficient and that replacing the storage box with a compressor would be relatively simple. You can purchase a complete kit for this area from CATuned, but their kit only comes with a twin compressor which I considered overkill.
So, onto making the mounting hardware.
Making the mounting hardware
I started by unbolting the storage cubby and making a full size paper template by tracing the edges and marking up the bolt holes, cross checking with some careful measurements. Then the various items to be mounted on the cover plate could be mocked up.
I planned to use some 1/8” aluminum sheet for the main cover and mounting plate, a thinner sheet of aluminum for a dust cover and a die cast aluminum box to mount the air connector and power switch. It turns out that aluminum sheets almost exactly the right size were available from Amazon, as was a suitably sized die cast box which was actually intended to be for a guitar pedal effect enclosure:
Aluminum sheet: https://www.amazon.com/ACXFOND-Alum...-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
Diecast box: https://www.amazon.com/DaierTek-Enc...+guitar+effect+pedal+enclosure,aps,199&sr=8-4
I have a CNC router, so entered the cut list into the CAD program and tested this out on a piece of cheap masonite. This allowed a complete photo build up of the compressor etc.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed tempImageTLW76D
With this all checked I moved onto milling out the aluminum, resulting in a nice clean plate. I machined this in two passes, starting with the interior cut out and holes, to ensure that I could ensure a solid mounting of the metal to the machine when I milled the plate edges on the second pass.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed tempImageRTA4zd
The visible metal components were then painted with some primer and black gloss spray paint and the various pieces of the compressor bolted into their final positions. The aluminum for the shield was an offset found in the junk box at my local metal supplier.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed tempImageMwIHO2
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed tempImagenbI4hy
Electrical work
The ARB compressor ships with a nice wiring loom, long enough for an engine bay installation and with connections for air lockers. Since I needed to run power from the engine bay to the rear, I would need to add wire for this and I did not need the locker connections, so I removed these from the loom and terminated the connections I needed to take to the front of the truck with some 75A Anderson connectors which you can see in Figure 4 above - red and black for the power supply and blue for the control line which also needs to be at 12v for the compressor to work. This would be connected to the Aux 3 pigtail I had installed in the engine bay (I did not want to use up the rear aux connection at the rear of the truck for this low power control line).
The ARB brushless single has a 60A fuse and draws 45A when operating, so I pulled an 8 gauge wire for power and a 14 gauge wire for the control line, inside a wire loom plastic tube, along the frame rail and up into the engine bay behind the battery. The control wire then ran across the front of the engine attached to an existing loom across to the aux pigtail by the screen washer bottle. The negative connection was made with a short length of 8 gauge wire to a chassis bolt close to the bed opening where the compressor would be mounted.
Final install and operation
The compressor assembly was then placed in the bed, the Anderson connectors mated correctly and then carefully inserted into the space between bed liner and rear wing where the storage cubby had been. It was bolted in using the same OE bolts. I also installed some bed side molle panels and the standoffs for this worked as designed with the compressor in place, just replacing the upper three OE bolts.
In addition to the compressor and the items shipped with it, I needed to add the following items to complete the air path: an ARB hose coupling JIC-4 (M) and dust cover, two elbow connectors JIC-4(M) to JIC-4(F), a 0.3M JIC-4(F) reinforced hose.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed tempImagePw4Fom
To operate, I press the Aux 3 switch, which prevents the compressor being used without cab access and ignition on. Then the compressor turns on with the switch placed next to the air connector. The brushless compressor has a very small built in air tank with a pressure switch, so the compressor pressurizes this to 100psi and then turns off.
I connect a 3/8” dia. air line to the ARB connector and then use an Apex Designs precision tire inflator to set the pressure and also deflate the tires to the desired psi (https://www.apexdesignsusa.com/products/precision-tire-inflator-pti).
Overall I have been happy with the result. It's clean, out of the way and allows deflation or inflation between 35psi and 20psi in 60 seconds per tire. The quality of the ARB items is excellent and they are very good value for money. Speaking of which, total cost ended up being ~$650 for all the parts as I found a sale on the compressor.
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed 1783057293542-ag
2024 Tacoma Air Compressor Build - compressor choices and building into TRD OR bed 1783058235588-ln
Toyotimothy
Timothy
Selmer, TN
Mounting location
Electrical work
I like it!
I was looking at doing something similar with mine but holding off due to money. lol
I like the fact that you have easy access from the bed. Good write up.
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
A lot of work when you could have just went this way. Zroadz bracket and a ARB twin fits perfectly.
The flaw with the engine compartment mounted compressors is heat will eventually slay the compressors much earlier than a bed or cabin mounted system.
TacoBirdinNW
2025 DCLB SR5
So cool. Thanks for this write up ! Learned a lot. It's one thing I hadn't even started looking into.
socotaco
socotaco
NorCal
26 TRD OR
My set up is similar but yours is much more elegant. Well done!
You have an amazing setup overall, nice job on mounting the Thor, very neat cuts etc.
I’d recommend the ARB hose connector as you can simply push a hose onto it and it locks on. I’ve found that with other connectors you have to use two hands, one required for pulling back the outside locking mechanism. Maybe the one you have works the same as the ARB.
your comment on access from below the truck is right on. You can blow the area out, wash as needed etc. However, I went with an open shield in my build, do you find that your compressors collects a lot of dust after off-road trips?
gofastdan
Thanks for the kind words.
I should buy the ARB hose connector. I've looked at them but just haven't pulled the trigger. Mine requires two hand, which isn't a big deal to me, but after a few minutes the air chuck does get quite warm and it looks like the ARB has rubber on it to insulate it, which right there would make it worthwhile.
When I built it out I was assuming the compressor would constantly be enveloped in a dust cloud whenever I am driving on dirt but I've found that's not the case. After over a year the compressor is still amazingly clean and I've never seen a need to clean the filters.
socotaco
socotaco
NorCal
26 TRD OR
This is exactly why I wanted to avoid mounting in the engine bay. ARB make solid products, but it gets pretty hot under the hood on a 4th gen, with the high efficiency engine, so finding an alternative mounting location seemed to make sense.
bsquaredMTB
El Paso, TX
Mounting location
Electrical work
GREAT write-up. I really enjoy seeing what people do to their vehicles. One question, you say you can use this setup to deflate and inflate. (Total noob question here) What is your deflate process using a compressor? Or are you saying you just deflate with deflators and only use the compressor to inflate?
gofastdan
Socotaco (and everyone else) might have a different answer but in general you wouldn't use the compressor to air down. Tire deflators like this are an easy way to do it. They can be a bit fiddly to set up but once you get them dialed in (at home!) then it's as easy as walking around the truck and screwing one on each tire. By the time you've worked around the truck putting them on it's almost time to work back around taking them off and your tires will be at whatever pressure you set the deflators.
If you buy a kit like this then you can use it to both deflate and inflate. You would deflate the tires by attaching the hoses to all four tires and then the gauge can be opened and closed until you get the pressure you want.
To me the screw-on deflators are quicker and less hassle and you don't have to monitor them but the hose kit is very convenient for inflating the tires when you're done being off-road. Both together with the compressor make for a quick and easy set up. I find that if it's not convenient and easy then I don't bother with the hassle of airing down....and inevitably wish I had after 20 miles of jarring potholes...
socotaco
socotaco
NorCal
26 TRD OR
I use an Apex Designs precision tire inflator (PTI) which has a few key features I like, (1) an accurate pressure gauge, (2) a push on chuck that holds the vale stem securely and then can be pulled off with one hand, and (3) an open/close slider control so that pressure can be added or removed from the tire without having to constantly push a lever or other button.
I have measured the time it takes to deflate and inflate from my usual on road pressure (35psi with hot tires) to a few target pressures that I use depending on the trail, between 15 and 25psi, and then open the valve control for this time as monitored on my watch. This gets me very close to target pressure in one go and can then fine tune as needed. It is interesting to note that with this setup the deflate and inflate times for the same pressure change are the same for practical purposes.
As noted before, we’re talking ~60 seconds per tire for 35 to ~20 and the same back to 35. YMMV depending on the exact hoses, connectors etc. used on your system.
bsquaredMTB
El Paso, TX
Thanks for all the info! Yeah I have the 4-tire inflator kit and some All Top deflators. I was just unsure if there was a way I didn't know about using a compressor. I'm always looking to improve my setup (as I'm sure all of us are in this forum!) Thanks again!
