2024 Tacoma oil filter comparison to 6-cyl Highlander and 8-cyl G4 4Runner
saerandy
Randy
Virginia
2024 SR5
Was going through my parts 'inventory' I have for maintenance on some of my vehicles and thought it might be interesting to some to see the oil filter size differences for some of the popular Toyotas out there. I didn't include the cartridge element for my 4-cyl RAV4, but in the pic from left to right are the filters for the '24 Tacoma, '06 6-cyl Highlander, and '04 G4 8-cyl 4Runner. Gave me some food for thought when thinking about Toyota's 10,000 mi change interval for the new 4G Tacoma.
2024 Tacoma 2024 Tacoma oil filter comparison to 6-cyl Highlander and 8-cyl G4 4Runner 97BA4A1C-0E72-46CC-9F7E-E929475809BD_1_105_c
saerandy
Randy
Virginia
2024 SR5
I should point out factory the installed ones on the new trucks are made in Japan while the replacements I bought at the dealer are made in Thailand. Doesn't bother me, but I just find that interesting. I doubt there's any real difference.
Sner
I’ll say this. Size has no basis. first, smaller oil filters afford better direct oil pressure. Second, oil grades have changed from ‘04 and ‘06 model years. This also affects oil filter size. Oil capacity also changes oil filter sizes, as does new fuel injection systems.
saerandy
Randy
Virginia
2024 SR5
My girlfriend says the same thing :)
saerandy
Randy
Virginia
2024 SR5
Direct oil pressure is determined by the pump, not the filter. Smaller filter = less captive media surface = poorer filtration: e.g. for Purolator 99.9% @ 40 microns for the smaller filters vs. 99.9% @ 20 microns for the larger filters. When the filter medium is half the area you must double the size of the micron rating to prevent differential pressure from doubling. Stick to your 10K oil change then and see you at 200K miles (322K kms) - maybe.
fightforfood247
Matt
Syracuse ny
2024 Tacoma trd off road
I likey this.
2024 TRD Sport-Bronze oxide.
Can the 2024 accept a longer filter? When I had my Versa, it was recommended to use an aftermarket filter that was another inch longer than the one listed in the manual, so that's what I used. Wonder if something similar would work on the Tacoma.
DK_L
24 Tacoma 23 ST hatch 18 FK8 18 Challenger Hellcat Widebody
Old thread..
Was thinking the same thing, was wondering if anyone has tried the Tundra filter.. Same thread size, and the gaskets are really close in size.
Pappy
Intermountain West
I don't believe the D1/D3 will fit. I had the same thought. I have a stash of D3 for my 3RZ and 2FE. The o-ring and base are larger. It appears it might screw on, but I suspect the base/o-ring is too wide to fit the filter housing on the T24A engine.
Here is a pic of a N1 and a D3. Maybe some day I will try it since I have a bunch of D3's.
2024 Tacoma 2024 Tacoma oil filter comparison to 6-cyl Highlander and 8-cyl G4 4Runner N1 vs D3 base-sm
DK_L
I was thinking the filter for the new Tundra motor, the 90915-10010. When I cross referenced on the Wix filter finder, it gave me the 57145 (or 57145XP) filter which is about 0.8" taller, but has the same thread, and almost identical gasket diameters.
Pappy
Intermountain West
Yes, the -10010 fits (currently running one). That part number has been superseded to 90915-YZZN3, and the -10010 is no longer available in the USA (I tried). My truck has seen the -10009, -10010, F1, and N1. They all fit.
There are differences inside. The F1 has two less pleats than the N1, but is taller. The -10009 has significantly more pleats than the N1/F1. Relief valves are identical. Drain-back valve appears to be the same, though the -10009 is a different color. Toyota filters are less than five bucks. Wix is more. Run what you want. I stocked up on the F1.
2024 Tacoma 2024 Tacoma oil filter comparison to 6-cyl Highlander and 8-cyl G4 4Runner F1 vs 10 vs N1-sm
