32spoke
Jason
Petaluma,CA
This subject has totally been hijacked. Can we get back to the topic of the initial thread?
Yes, and I apologize.. this is my fault.
The last “on topic” comment, related to Stillen QC on an aftermarket air cleaner assembly for the Tundra. For me, this means that I personally would wait for someone else to purchase The Stillen air cleaner assembly first to verify my QC concerns, that seem to plague their Tundra air cleaner assembly variant.
HBNARO
Scottsdale Az
2024 TRD PRO Terra
Thanks for the course correction! I am with you as I am not an early adopter and prefer to let the more adventurous establish the track record.
Slappy
tacoma , highlander
i had a TRD cold air intake on Yaris I had , that did actually add alotta spunk to it's 4 banger & made quite a sound u could hear me coming a block away . I had TRD sway bar ,support pillars for the front end , fat wheels , cornered superbly But that Yaris was worst Toyota I ever had , I had got it to long commute in to save on gas back in 2008.
bctaco24
2021 Tundra Sport Premium, 2024 Tacoma Sport Premium
I mean I’ve been running 91 since mile 0…. It’s got some umph on it. Love mine.
87 for me, truck is designed for it so I have no issue.
I traded my 2021 Tundra for the '24 Sport Premium non-hybrid Tacoma and had some remorse due to the lack of power off the line in comparison (I realize the differences in power curves between the engines).
For general around town and NOT hauling or running through mountain passes 87 seems fine.
Was running 87-89 mix for the first 2000km and the truck simply didn't seem to have the pull I was hoping for (I owned a '21 Taco as well).
After a couple of tanks of 91 the motor definitely feels happier and pulls better, especially in both Tow and Sport modes.
32spoke
Jason
Petaluma,CA
That is a great question. Since the ecu already plays with timing, based upon the fuel quality, then the software “could” float even more spark advance, if it has parameters setup to do so.. meaning that the truck may max out it’s maximum ignition advance with premium unleaded fuel and not advance anymore if a person dispensed ms109 race fuel into the fuel tank. Sorry for the lame answer, and likely that the only people capable of answering this question would be OE engineers, doubt they would disclose this, and the aftermarket software tuners.
I’ll try it out and see what the old “butt dyno” says
Carolina Buckeye
Wilburn
North Carolina
24' Tacoma iForceMax OR Premium
Yeah I totally agree 87 is completely safe, the Toyota engineers know their stuff. Just thought the power increase without any tune was notable.
The mechanic at the dealership I bought my Taco at told me there was absolutely no need to run high octane fuel in my truck. Said it was designed for 87 octane. I trust Toyota seeing how they designed and built the truck.
There is no need. But this engine is a shared dirvetrain with the Landcruiser. It adapts to higher octane and can make more HP and runs smoother on higher octanes. Not a need, but it’s pretty cool when you try higher octanes. The manual says that 87 is the minimum, not the only octane. You get a cheap tune option on this thing anytime you want it, and to me that’s as cool as it gets. People would have dreamed about that.
And, respectfully, a service center mechanic is not a toyota HQ engineer.
Yotota
SW WA
24 TRD
The Tech has no idea how the ECU is tuned by Toyota engineers.
And it's already been proven the the ECU will adjust for 91/92 octane fuel (likely with timing advance, but could be more parameters too). It's a proven power increase.
And if Toyota ECU programming does it stock, it's perfectly healthy for the engine.
Most people don't drive hard enough to need more power. But there is a noticable difference in how the engine runs - My truck is smoother and less chuggy.
