- First Name
- Ray
- Joined
- Nov 13, 2024
- Threads
- 10
- Messages
- 235
- Reaction score
- 191
- Location
- Pennsylvania
- Vehicle(s)
- 24 tacoma pro
I was in the same boat as you I traded my 2011 rock warrior with 86k on it and it was in great condition
Every automotive hydraulic system in an automotive application, will have a pressure side and return side. Pressure is developed by a pump with spikes the pressure from nothing to a specified pressure by an engineered requirement. Creating the pressure creates heat and hydraulic force to address the requirements of the design of the system- this applies to all circulating fluid hydraulic systems. The transmission pump, behind the torque converter, generates the required pressures specified by an engineer. After the fluid passes though the transmission, or the demand side of the hydraulic system, this applies to air conditioning, hydraulic power steering, engine cooling system, and an automatic Transmission. After the fluid address the “demand” or hydraulic force demands, the fluid heats up and usually passes though a heat exchange unit- at this point, the pressure has already dropped, and in the case of an automatic transmission, by the time the fluid passes back into the transmission, after flowing though the heatThe issue involves casting sand remaining in the torque converter, apparently due to improper flushing. Given the pressures within the transmission and the size of the sand grains, it's unlikely the particles will settle; the filter may or may not capture all of them. However, the grains are large enough to lodge in the solenoids, leading to shifting problems. This may partially explain why not everyone is experiencing the exact same issue—some individuals report no problems, others experience intermittent issues, and some face complete transmission failure.
TacoFreak, I agree that Toyota probably doesn't have a handle on the scope of the problem. The cost made my stomach turn. I chose not to get the extended warranty, and I'm thinking that I might have to unload my Trailhunter before the factory coverage expires (if I continue to have problems after the repair).@BorealTaco That is terrible news, but thanks for sharing. The more information that owners have the better we can prepare for what might happen to our trucks.
That TSB covered the trucks Toyota admits might have problems, but there have been other transmission failures in trucks outside the range. So obviously the failing transmission events are still happening and you have to wonder how many more there will be. At this point you have to wonder if even Toyota knows exactly what is going on.
That cost is amazing and you would think that alone would make Toyota want to get to the bottom of this. But so far they are playing their cards very close to their vests and leaving us in the dark.
Good luck with getting your truck fixed. Did your dealer give you an estimate of how long it will take to fix your truck and did you get something to drive in the meantime?
I love my Pro but I wonder if one day, out of the blue my truck will do exactly the same thing.
Hopefully Toyota gets you on the road in a matter of weeks vs months! I think Toyota dropped the ball with the early failures, many were nearly 2 months.My 2024 Trailhunter had a transmission failure this morning with 750 miles on it, and my VIN was almost 3,000 after the published VIN on T-SB. The hybrid module assembly was included in the estimate (that alone is priced at over $19,000).
Shifted the car into R following a very cold morning start and the truck shuddered for a few seconds. Following the shudder, no backward movement even though truck was still in R. Finally got it to back up and no transmission engagement when shifted to D. Shifted to P and then D and transmission engaged but would not shift out of 1st gear - tried accelerating to 4500 rpm and still no shift. Following a bit of a meltdown/venting call to the dealership, I turned the car off and on 2-3 times and the transmission started shifting. I was 1.5 hours away from the nearest Toyota dealership and drove it there with every warning message under the sun cycling through my instrument cluster - they got my truck in right away and gave me the bad news. Thankfully it's obviously under warranty because they told me the entire repair will cost north of $27k!
Never posted here before and haven't read through this entire thread. Just wanted to share my experience with the failure. I love the Trailhunter and am hoping that this is the last catastrophic event with it.
A $27,000 repair bill isn’t a money maker?Quick update: I just opened a "case" with Toyota Brand Engagement Center. After my truck had the codes cleared at the initial dealership that I stopped at, I drove it to a dealer in my town on Wednesday evening. I called today and they told me that they haven't been able to get the truck to throw the codes again, so they haven't done anything yet (no parts ordered, etc.). So I called Brand Engagement and opened a case. Not sure that it'll matter. It would be nice if they would expedite things, but from what I understand - these are not big money makers for the dealership.
