Tonneau cover + bed rack?
emerica243
Matt
PA
Fusion
Is it possible to to have a tonneau cover installed and also install a bed rack system together or do they interfere?
Looking at getting my first tacoma, eyeing up one that has a cover and one that has a bed rack. I would like to have both a cover for the bed and a rack for accessories.
Norsk
Greg
Downingtown, PA
I have Retrax XR Pro with KBVoodoo crossbars. It is great setup. If you're willing to spend that much money on Retrax XR Pro.
emerica243
emerica243
Matt
PA
Fusion
Thank you for the insight. I see how that works now. The truck I was looking at has the Toyota Bed Rack LD installed. And seeing how that looks like it mounts compared to yours. I'm guessing a cover can't also be incorporated.
FlyAngler
NH
I had the the Retrax Pro XR on my short bed 3rd gen with Yakima Overhaul HD on top. For my Trailhunter long bed, I didn't want to lose the bed space to a retractable cover. I couldn't find a roll-up that would fit with my Overhaul, so had to change to the BAK revolver XTS (roll-up w t slots) paired with RealTruck Elevate FS Rack (scroll down). No lost bed space. Works for me.
2024 Tacoma Tonneau cover + bed rack? 1000001335
Tungstenisw
Tacoma TRD OR
Look up Billie Bars. they are top quality, affordable (relatively speaking) and work with most roll up tonneaus
TRUKD Bed Racks
Jake
Pittsburgh, PA
Tacomas!
TRUKD Bed Racks
Jake
Pittsburgh, PA
Tacomas!
A bed cover with T-Slots is the way to go! Our racks work great with T-Slot covers, as well as sit-on-top covers like DIamondbacks, Extang Solidfolds, etc.
nurp42
TRD PreRunner
'24 PreRunner
Could any of you guys with any rack/cover combo please let me know if you lose the functionality of the bed rail tie-down system once installed?
FlyAngler
NH
For covers that attach using the stock Toyota bed rail system, the tie downs still function but are just a little less functional because they no longer have the same range since the cover attachment points limit it. Just think it through during install so you don't have to undo things later. I find that placing the tie downs strategically between the cover attachment points still gives me enough flexibility.
The issue is that you can't slide the tie downs the full length of the track if there is something "permanently" mounted like a cover. Not a huge problem, but definitely worth thinking about during install.
HTH
djDubbs
I have a 24 trail hunter with the rear carriage bar factory installed. I have looked at ways to modify the bar or the cover mounting brackets to make it all go together but have licked out thus far.
djDubbs
Lucked
infantry317
MN
2024 Tacoma OR
No, if I go through a car wash a little water gets in but not bad at all. I put the tonneau rail clamps near the Billiebars bracket so it pulls down the rail harder in that area compressing the weatherstripping.
