Stock OR Shocks - Potential Upgrades
BAQ717
‘24 Tacoma TRD OR
Wondering what the consensus is on the stock OR shocks in comparison to the previous gen 51 and 61 series Bilsteins. Are these better than those given that they’re dual reservoir? It’ll be interesting to see what aftermarket options Bilstein will have later this summer. I imagine they’ll have a fairly reasonably priced dual reservoir that’s an upgrade to the OEM option. Maybe?
Powhunter
Alberta
I am extremely impressed with the stock OR suspension. Absorbs big bumps very well and is very compliant on rough trails. The only reason I could see you would want to upgrade to Fox or King is if you wanted a 2.5”+ lift or were racing.
The shocks are the same diameter as the old 5100s but with a remote resi. I think you’d have to step up to 6100/5160 in order to have an upgrade over stock. Integral bump stops mean an above coil spacer is no longer a detriment, and with the extra travel a small preload spacer isn’t going to be bad either. To top it off, 33” tires bolt right on. It’s a seriously capable truck, even in stock form.
BAQ717
BAQ717
‘24 Tacoma TRD OR
I assume it’s not normal then to feel a clunk over sharp pot holes? The shocks otherwise seem great but I get a random clunk from the front left side over some otherwise mundane road imperfections that force a quick rebound. Possibly I got a defective shock but some on here have mentioned it’s normal behavior for the internal bump stop? That’s what’s been leading me to consider upgrades. I’d be more than happy with them otherwise.
Muckle
I can report similar behavior in my OR. I had correlated it with the 300lbs in additional weight I've added via rock slides and skid plates.
BAQ717
BAQ717
‘24 Tacoma TRD OR
One side or both? I only feel it on the left side of my truck. Possibly some mounting points need torqued properly.
Muckle
I haven't paid that close of attention; after I heard it a few times, I just make sure to hit any bumps/potholes very slowly to avoid it.
The clunk is the nature of the bistien shocks.
Different shocks but similar valving https://duckduckgo.com/?q=bilstein+...i=https://www.youtube.com/watch?v=js0yxfIHf-Y
Rocko
Oregon
2024 trd w/upgrade
So, I have a 24 TRD OR and initially I was not too impressed with the suspension, and the bump stops were very disappointing. Well, at 12k miles in now, the bump stops don't seem to trigger on speed bumps anymore and everything has loosened up a bit. Give it time before you replace everything. That being said, I will probably switch to some Bilsteins at some point down the road, but the stock TRD has come around nicely.
Wahhabm
Monther
Apart from kings or fox is there an upgrade that will not require 4k?
Wahhabm
Monther
I want to make sure on road performance is very comfortable around the shitty roads and potholes in texas. Not too much dipping upon braking, but without too much lean on cornering. Am I asking for the impossible? I noticed since I added all kinds of skid plates, that the suspension performance may have been degraded a bit. Some folks suggested putting some alldogs springs in the front to level it. There isn't too much assurance thought that it will enhance performance. They say it is subjective.
Wahhabm
Monther
But they are 3k now. If they go on sale for a good price then yes. I wonder if the solved the reservoir mounting issue?
jahferg
Jahson
25 TRD off road
Id highly recommend the eibachs stage 2, fully adjustable and just under 1k. And have been way happier with the eibachs over the common 5100,s used on last 4trucks
2024 Tacoma Stock OR Shocks - Potential Upgrades IMG_20260411_175621806_HDR
