Belt chirp when a/c turns on
vi4thgen
Vancouver Island, Canada
Toyota Tacoma, 4th Generation
Hey there, I bought my 2024 Tacoma TRD sport new in May, around 2k miles is when I started to notice the same squeak noise. I’ve taken it to the dealership and reported it every time I had my oil change and tires rotated, at 11k miles now and they scheduled me to come in today. Turns out there is an active case on this issue and they had to do a conference call with the manufacturers.
They determined the issue is due to the “clutch magnet” in the AC compressor.
They ordered the following parts:
1.Clutch Assy, magnet
2. Gasket kit, overhaul
3. Two ring snaps
Hope this helps!
Thanks, I’ll have them try that!
MarineVet6113
2024 Toyota Tacoma TRD OR
I also have like 2 chirps on a cold start and I am at around 1700 miles. I don’t seem to hear it if I’m starting and the A/c is in the off position. I don’t know if it was there before. If so I never paid it much attention. I will almost swear I hear it a random a few times when I first start driving but it’s kind of hard to tell. Seems like after everything is warmed up and after 5-10 minutes I don’t notice anything.
BOLDTACO
United States
2024 Toyota Tacoma SR5 4x2 cold pack
I have a 2024 Sr5 and it had this A/C chirp.. long story short I took it into Toyota and it needs a new alternator. Currently awaiting a rental due to the alternator being back ordered (2-4 weeks...) I will update when it is back in my possession!
BOLDTACO
United States
Of course every time I try to take a video, it doesn't happen. I was thinking the same thing with the a/c clutch. I'm going to try and get it in to the dealer soon. I'll report back with their findings.
my dealer is replacing my A/C clutch due to this issue. of course though, it's on back-order.
cowboypep
Jack
Phoenix
2024 Tacoma TRD Off Road
I have this problem with my 2024 Tacoma. After a few thousand miles it started getting 2 chirps at startup and then it periodically chirps every 30 seconds or so when the HVAC is turned on. The dealer is planning to replace the entire compressor.
DCtacoma
Christopher88$$$$
2025 tacoma trd sport
I recently purchased a 2025 Tacoma Sport, and at first, I didn’t think much of the noise I heard when starting it up I honestly thought it was just a bird chirping nearby. But I started paying closer attention and realized it only happens if the A/C is on during startup.
The other day, I was in a parking garage and turned the A/C on about five minutes after the truck had already been running. As soon as the compressor engaged, I heard the same chirping noise, and this time it echoed so it was definitely coming from the truck.
It seems pretty clear the sound is tied to the A/C compressor kicking on. What I’m wondering is: how is this happening to so many people and there’s no TSB or recall for it? Is this actually considered normal? And if not, what’s the root cause?
vi4thgen
I took my truck to a dealer again and they were able to replicate the sound and confirm it is something with the AC (I think they said it was the AC clutch). Parts are on back order with no ETA currently, so I’m guessing this may be a larger issue and more parts are being ordered than originally anticipated. I’m quite surprised there hasn’t been a TSB or a recall yet.
Will update here once the part is replaced.
DCtacoma
Christopher88$$$$
This is a clip off the noise it hits at around 3 second mark on the video.
yes please update us! I’ve just updated my post with video and audio of the issue too.
laocie
Jeremy
2025 Tacoma, 2024 4runner, 2021 Tacoma
Mine chirps at cold start without the AC and while I’m driving too
slater
san diego
2024 tacoma sr5/2wd, white
Had an extensive conversation with the shop foreman after I sent him this thread...
He reached out to toyota again & discussed all the dealers ordering clutch / pulley assy's within this thread & end of the day he explained that there needs to be a revised component released & you guys are just waiting for the same shit thats already on the truck....
He said, he can order my a compressor pulley but wont resolve the issue long-term, until they. revise the existing part.
Told me to sit tight & we will talk again at my next oil change. I have 6k miles on it now...
As of now he has no idea if theyre currently working on developing a revised part now or not, just said theyre aware & investigating the issue.
I also brought up to him,
Just under initial first thing in the morning cold start & take-off, seems like the trans short shifts, shift prematurely at the first shift & then its fine after that, until the next cold start.
Hes seen it, has no idea if theyre working on it, or normal characteristic, will address it at next oil change also...
mrgooden
Richard
Chesapeake, Virginia
Mine has a clutch on back order for the compressor. Had chirp at cold start up since day one. Waited about a year to take it in because it consistently chirps during engagement now, not just when cold.
24 Limited.
Richard
thefinalstraw
Massachusetts
2024 Underground TRD Sport 4x4 Premium
i had essentially the same exact conversation back at my 10k service after he called toyota and talked to them about it. as i just hit 14k, i figured i'd pop in here to see if there is any fix yet. the chirp pisses me off to no end.
slater
san diego
Nobody follows through with updates.....:headbang:
I havent hit 7k yet, im going to bring it up again at 10K oil change which probably wont be till next year...
or when I go in for the brake line recall....
I got nothing for you..
I honestly don't think there are any updates. Latest I've seen is that they're just replacing all these different parts hoping for a different outcome but it still persists. Seems like it's an engineering issue, or the famous Toyota tech line of being "normal".
Pootklopp
Usa
2024 Bronze Oxide TRD OR
I had a similar talk as others here have had. They called Toyota HQ, they were advised it's a nuisance and does not effect performance. They followed with replacement is not recommended at this time.
My tech and I felt like it's something they know is wrong and are working on a fix. I had replaced once already, I'll keep bringing it up when I bring it in and wait for a fix at this point.
