Regular fog lights VS Rigid's
Halifax, NS
2025 TRD Pro
Can anybody confirm the dimensions of the glass area are the same on the OEM versus the Rigid's? I'm trying to find yellow vinyl to tint my fog lights, and I also would like some for my TRD Pro light bar, I'd just upgrade to the TH Rigid fogs, but this is much much more cost effective
I’ll even take a source for stick on vinyl big enough to cut to size myself and apply, but not heat applied crap
2024 Tacoma Regular fog lights VS Rigid's 1740776674971-0q
Sner
i bought these, and they fit if it helps
rijc99
The opening on the plastic trim is the same so I’d assume the glass is most likely the same area? All the film I’ve seen are just ever so slightly off and never cover perfect. It’s not noticeable unless you’re right up on it. You might be better off getting a full sheet and doing it yourself. A little bigger than the glass with a small tab would be good in case you decide to remove it later… easier to start peel. Also, white led with yellow film doesn’t look quite yellow when lit unless you make it pretty thick. I tried Lamin-x and one other brand that I can’t think of right now.
2024 Tacoma Regular fog lights VS Rigid's IMG_5730
2024 Tacoma Regular fog lights VS Rigid's IMG_5729
2024 Tacoma Regular fog lights VS Rigid's IMG_5728
Will721
Will
Quad Cities
2025 TRD OR
For anyone's future reference, no the OEM rigid fogs are not the same at all. They have a much smaller lenses than the standard OEM fogs. You can buy amber and yellow vinyl covers from:
https://tacovinyl.com/
