Romer
Ken
Centennial, CO
I picked up my ARB bumper yesterday and installed it. It took about 4 hours, but went on pretty easy.
No instructions come in the box. Fortunately when I ordered it I was able to get a PDF file from the Toyota (attached)
The instructions say you need to order a new wire harness from Toyota, which I did. The clips and retainers are all layed out to the ARB design.
The bumper comes with 4 new Sonar sensors. You do reuse your Blind Spot Monitor sensors (Corner sensors above bumper)
The only issue I had was after I was done, the Parking assist was disabled for front and rear. Everything else going through the harness seems to work; lights and Blind Mode sensors
The instructions tell the tech to perform a Parking sensor calibration and I don't have that capability.
EDIT: Update see post #16. If you reuse the stock sensors in the stock locations everything works and you don't have to do Calibration
Searching the internet I didn't find anything about my issue. I asked a person on here if the shop who installed his bumper recalibrated the sensors and he told me that they sent it to the dealer to register and calibrate them.
I reached out to the Toyota Dealer I bought the bumper from and he confirmed with the lead service tech that the system goes into open loop until they program the new sensors.
I will be taking it to the dealer on Tuesday to have that done.
I had two questions before I ordered it
1) Will the bumper be heavy enough to cause any droop on the rear? The answer is no, it measured the same before and after
2) Do I need to order the new harness? I likely could have made the stock harness and parking sensors work, but I didnt try
The other aftermarket rear bumpers reuse the existing sensors and harness and likely could have done that here. I did remove the stock harness and sensors from the old bumper in case I need them for troubleshooting. I could plug the 4 old sensors in and connect it to the truck to see if the parking sensors work again, but will follow through on the Toyota Calibration
One other note, I bought this stand on Amazon to remove and replace an Aux fuel tank in my Land Cruiser (pictured). Once the bumper was complete on my work bench, I transfred it to this stand and worked it into place. It made it easy for one person to install it
Very happy with the robustness of the design. I wish I knew ahead of time using the new sensors required calibration as I may have played with the old sensors before fully assembling the bumper. Not sure if they would have fit and stock has different sensors center vs outer. The ARB 4 sensors are all the same and the same as the stock center ones. I am sure I will be happy in the end to have used the new sensors and harness :)
gofastdan
Looks great! I'm curious as to how much it costs to do the sensor calibration since that then factors into the overall cost of the bumper/installation...
Romer
Romer
Ken
Centennial, CO
I do have a question maybe those with a trailhunter can answer. There is an unused connector that clips to a bracket on the pasenger side of the bumper. I am guessing it is for accessories like lights. Anyone know for sure?
Romer
Romer
Ken
Centennial, CO
I will post up after I get it done. The instructions say to calibrate these sensors and the Blind Spot monitors. The Blind Spot monitors are working since they are the same sesnors (reused), but the angle may have changed
tkrum015
Ted
Olympia
Maybe the extra plugs are for the arb oval lights for this bumper?
gondem07
Demetrio
2024 Toyota Tacoma TRD Sport
Wow. Looks great. How much did it come out to with the harness as well?
Romer
Romer
Ken
Centennial, CO
My club has a discount with this local dealer. Some dealers I called couldnt even look it up or get it. Some could, not sure why
Duce95
Big Deezy
2024 TRD Off-Road Premium
My dealers online parts site is a tad less. I’m coming out to $1450 for both parts. Not sure what they charge for shipping though.
Earnhardt Toyota parts.
TFOUTS
Timothy
Northwest Florida
RokeHi
TRD PreRunner
The Copper State
I get my parts from the same dealer. But they do add on shipping, no local pickup.
TFOUTS
Timothy
Northwest Florida
On my Trailhunter I do not have anything plugged there. The wiring harness just above there is the harness for the Rigid oval lights in the bumper
Romer
Romer
Ken
Centennial, CO
Thanks, so you are confirming you have the same unused connector. At least I didnt miss anything in my install
I wonder what it is for?
TFOUTS
Timothy
Northwest Florida
When I traced the harness that the connector is spliced into all the way to where it ends passenger side, it goes behind the right sensor. So, I wondering that the connector is for diagnostic testing on the bumper sensor, i.e. re-calibration.
Lando
I like this bumper, well done. Though not a step, it does give a toe hold when the tailgate is down. Seems more like a truck bumper.
It’s not so much an issue with the Tacoma as it is a small truck. On the Tundra it’s a design fail for a pick up truck that when the tailgate is lowered there is no bumper flat part to step on to access bed. Clearly not designed by a truck owner, the bumper design is style over substance.
