TX-BluStreak
Houston
25' TRD Pro - Underground
I just installed these billet tie down points on my 2024 Tacoma TRD ORP. If you want a pair, head over to https://billettiedowns.com/ and use code β€œGHOSTED” to save on your purchase!!
I bought a set of these but I'm having a hard time removing the OEM from the spray-on bed liner to install these. Pls advise. Thanks!
Halifax, NS
2025 TRD Pro
Added Versatrax for some extra tie-down locations. When the rings are removed the tracks are flush and bed mat lays flat over the top.
You’re today’s bad influence, these costed me a ton with tariffs but I LOVE the idea, I am going to trim my rubber mat to fit the front anchors better but that might be a Sunday issue
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5342
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5341
nurp42
TRD PreRunner
'24 PreRunner
Sorry about the extra $$ you had to pay, but yeah, I think you'll find them helpful.
Bravada
S.E. Texas
I bought a set of these but I'm having a hard time removing the OEM from the spray-on bedliner to install these. Pls advise. Thanks!
Your rail end caps are stuck on with the spray-on bedliner? Or the tie downs on the floor of the bed? When I installed my front bed Molle panel, I had to take a razor and a pick to get the bolts out of the bed floor. I cut carefully around the bolts, and used the pick to dig out the bed liner from around and in the head of the bolt, so I could get the bit in the bolt.
JD11
Jimmy
It compliments the AWE exhaust perfectly, and sets me up for Overland Tailor Tuning.
Do you have a video of the exhaust/intake combo sound? I am looking at those 2 upgrades along with the OTT tune so curious what it would be like.
Bravada
S.E. Texas
I did make a video, but when I try and upload it, there is no sound. It must be an Apple .MOV issue. I'll try and use my wifes Android later.
Bravada
S.E. Texas
Bluetooth was the culprit, my phone was evidently pairing with the truck and killing the audio. Here you go. The rear exhaust video was on high idle, the intake video was after the it went off high idle. Not professional level audio recording, it sounds much better in person.
JD11
Jimmy
Appreciate you! I think AWE nailed it with this. I’ve heard others say it’s pretty minimal droning and not too obnoxious driving around town. And 100% sound better in person, just need to find someone who lives around me with one so I can just pull the trigger on it. Thanks!
