Devildog81
minnesota
2024 tacoma trd offroad
Which Icon wheels are those? What’s the offset?Do they poke out past the fender flares a lot?
I,m wanting to run the same tire on new wheels, but unsure on what specs/offset to get and have minimal poke.
Thanks!
I’m running the same icon wheels, recon SLX +25 offset.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5689
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ IMG_5695
2024 TRD Sport-Bronze oxide.
I took possession of my TRD-OR/MT truck yesterday. Drove it home from the dealer around 250 miles and got 21mpg. Truck bed will be covered with a canopy camper from Dirtbox.
Today ...
  • Installed the OEM front molle panel. It will hold my 13 gallon water tank and the RV water pump.
  • Installed driver's side Rago molle panel. It mounts my CO2 and propane bottles.
  • Pulled the thimble sized oil filter off (90915-10009, aka N1) and replaced it with the larger F1 filter to see if it fits. No problem.
Thanks for the filter update. Read about this on another forum but no one knew if the longer filter would fit. They also wondered if the bypass valve of the larger filter would operate different for this engine. Also, the larger filter may be a resin vs. pleated filter of the N1, (if that makes a difference in filtering).
Pappy
Intermountain West
Thanks for the filter update. Read about this on another forum but no one knew if the longer filter would fit. They also wondered if the bypass valve of the larger filter would operate different for this engine. Also, the larger filter may be a resin vs. pleated filter (if that makes a difference in filtering).
My wild guess is the N1 and F1 are identical internally, except for the length of the media. I will be cutting my F1 open in July when I give the truck a break-in oil change. At some point I will cut open a -10010 filter.
Pappy
Intermountain West
Back at it. Yesterday and today ...
  • Installed Victory 4x4 sliders.
  • Installed the "smaller" Canada mudflaps (PK389-35R00-P1).
  • Removed resonator and installed the TrailHunter exhaust tip (PT226-35241-AA).
  • Wired the rock lights on the Victory 4x4 sliders to Aux2 dash switch.
  • Wired a relay off the Aux3 switch for future ... cuz it was there and I could.
The provided wire pigtail for the Aux1-3 switches. I installed a 4-pin Weather Pack connector. Currently Aux2 is wired to the rock lights on the sliders, and Aux3 is to a relay (for future). Aux1 will be for the driving lights on the front bumper.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ Aux pigtail-sm
The Aux3 relay mounted on driver's side fender, triggered and grounded.
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ Aux3 Relay-sm
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ Victory slider-sm
Starman202
RTP, North Carolina
I got the Suma mirrors installed. Nice field of view improvement.
I really want this as i'm spoiled by auto dimming mirrors [except for my Civic Type R, i had purchased Rexpeed blue mirrors for those]. I really wish SUMA didn't have the logo itched into the glass. But anyway, did you have to cut off the tabs on the mirror to make it fit?
Bravada
S.E. Texas
I didn't cut anything.
Bravada
S.E. Texas
Got my AJT DESIGN Shift Knob installed. The spring clip holding the original knob on gave me a little resistance, however as the Borg say, "Resistance is futile."
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.05.29
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.30.00
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.22
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.08
2024 Tacoma What did you do TO / WITH your 4th gen Tacoma today?! πŸ‘¨β€πŸ­ 🧰 πŸ“Έ 2025-04-02 23.36.12
timetoeatpotatoes
site
TH
Hey bravada do you have any fitment problems? AJT shift knob causes the truck to think I am not in park when I am in park.
I reached out to AJT and they kinda gave me the runaround and told me to try to lift it up and have the set screws hold it up but it binds up.
Bravada
S.E. Texas
So far no issues. I believe it came with instructions to not bottom it out on the Tacoma.
timetoeatpotatoes
site
TH
thanks, ill give it another go. feels like either it binds up (too high up) or does not think im in park (too low?)
Bravada
S.E. Texas
I'll try and make a short video later, to show it functioning.
